Passenger Door hard to open/wind noise
It would appear that the passenger window doesn't go up and down when opening as much as the drivers door thus making it a little hard to open. Wind noise was the initial problem only to find out about the window in my search for the noise. I just get a little road/wind noise at or above 75mph from the passenger upper back window area. Do i need to take to the dealer for an adjustment or do i have another issue?
It full opens or closes on one tap. I even tried the re-calibration trick i found on the Aston thread. They thought it was the same problem with both cars. My indie re-calibrated my seats which turned out wonderful. He says that if you ever replace the battery the seats will lose calibration. Do the windows??
That's what I'd try first thing, it's easy and free.
I have no idea if Aston has the same procedure, but here it is and it doesn't matter which direction is first;
HOLD switch up or down TWO SECONDS longer than full glass travel, the release and hold AGAIN for two seconds in same direction.
Do the opposite direction same as first.
MLRjr (12-09-2019)
Cee Jay (12-09-2019)
SableCat
03-23-2017 07:26 PM
cosworth
16
05-21-2008 01:45 PM
