Pedestrian Impact System
Hi,
I have a xk dynamic r, which in cold and wet wet weather display a message to check pedestrian impact protection, during warm weather the warning doesn’t appear. I have the supercharged version, so access to the front impact sensors is not possible from inside the engine bay, due to the supercharger cooling infront of the main radiator. Is there a way of checking if these sensors are at fault with an OBD2 diagnostic, and how do you access the sensors if they are faulty. Any advice will be much appreciated.
Hi,
I have a xk dynamic r, which in cold and wet wet weather display a message to check pedestrian impact protection , during warm weather the warning doesn’t appear. I have the supercharged version , so access to the front impact sensors is not possible from inside the engine bay, due to the supercharger cooling infront of the main radiator. Is there a way of checking if these sensors are at fault with an OBD2 diagnostic, and how do you access the sensors if they are faulty. Any advice will be much appreciated.
Staatsof
01-09-2014 12:44 PM
