Pink Fluid Leak?
Hoo, baby.... That's either Transmission Fluid or Power Steering Fluid, depending on where it's coming from. You'll need to do some investigating. Both conditions are fairly serious, but the Transmission could be more costly.
Depending on your mileage, it's probably time to do a Trans Pan and Fluid replace anyway. The plastic trans pans have been known to crack/leak after awhile.
Materials are like $150 for a pan/filter/bolts on places like Amazon. You'll also need a mechatronic sleeve, about $10, and between six and ten quarts of fluid, which prices can vary WIDELY. Labor shouldn't be more than like $300.
khsjsilver (07-08-2019)
OAT Coolant has a distinct odor and if your reservoir is full it's not likely the problem.
When you had your tranny serviced, did they fill it with Lifeguard 6 or something else like Mercon? Lifeguard 6 is golden in color so if that's what they used, that's not your problem either. To Cee Jay's point, the transmission is fully arrears of the under scuttle so you should be able to see if the leak is coming from there without having to remove the under scuttle.
Take JT's advice and remover the under scuttle to get a better look.
Can't explain to reservoir being full but it does certainly look like PS fluid and almost certainly is if all your fluids are OEM.
With my 2007, the rubber gasket failed a year ago, and I bought a replacement from the local hardware store.
I took a picture looking up through the whole. Is this the radiator drain plug you are talking about? This must be the leak.
Ken
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/810x1080/leak2_1cdc56243ad89f4693e17da54247a11d9fd59034.jpeg)
You can pay your dealer a three digit amount, or go to your local hardware store and buy a neoprene gasket for $0.25 to repair the problem.
The following 2 users liked this post by Reverend Sam:
khsjsilver (07-08-2019),
Ranchero50 (07-08-2019)
