Playing music through your droid using Bluetooth
The only way I can get it to work is through the RCA inputs which is installed as an option. The stereo doesn't support bluetooth audio. I run Pandora and all other music this way and it sounds fine. I tried the USB with the droid and it did not work. I also have a USB stick with MP3's loaded which works as well
Dan,
Are you using the Jag connection with your phone?
With the connector I can run my iPhone quite easily i.e. the iPod runs easily.
When I try to run Pandora it starts and then yours off. It also says no volume control. Am I missing something? What type of phone are you using?
