Please help with 12' xkr codes
Hello everybody....
1st time posting...
My 2012 xkr started running a little rough, figured it was time for a tune up.... then after two weekend trips of maybe 120 miles the restricted performance light came on and it started running really rough. I scanned it and it came back with 6 codes. I will attach screenshots of codes....any help or advise on this would be much appreciated. Thanks in advance.
1st time posting...
P0019-00 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor B - No sub type information NOTE:- Circuit VFS_EX_B -
- The relative positions of the crankshaft position sensor and camshaft timing plate teeth are not correct
- Engine timing incorrect
- Timing chain installed incorrectly
- Variable valve timing forced fully advanced
- Check engine timing. Check camshaft sensor timing plate is installed correctly. Check timing chain is installed correctly
