please help identify an engine part
2013 xkr. Guys i got an oil leak from this part that is bolted to the front side of the upper engine oil sump and i have searched high and low to find out what it is? The part number rubbed off it. Also surprised to find out that there is no gasket between the lower and upper oil pan...its just bolted directly together.
I've no idea what it is as there's nothing like it on the XK that I can recall.
However, as it's fixed to the oil sump, it must surely be a level sensor, a temperature sensor, a pressure sensor, a pump, a filter or a heater.
Admittedly, it doesn't really look like any of those but what else could it be? 🤔
Richard
Richard
Looking at page 77 of this manual it looks to be something to do with the fuel cam timing?
Richard
Received 3,226 Likes
It's the oil vacuum pump which is a fairly common oil leak point on the AJ133 (and I guess the AJ126), see this recent nearby post and especially the link inside it: https://www.jaguarforums.com/forum/f...1/#post2629500
The following 3 users liked this post by jahummer:
ExcelsiorZ
04-02-2022 11:32 AM
daboss085
08-31-2013 06:35 PM
