PLEASE - Is there Definitive Battery Guidance -2010 XK
Old 06-28-2023, 02:45 PM
CA Jag's Avatar
Just the OBD wireless connect.
After last battery disconnect/reconnect, everything works. Solution for now is a C-Tek MXS 5.0 This seems to be the replace for the 3300. I'll disconnect the battery when it's in the shed (no power) for more than a couple of days (the time it's taken to drain to 12.4). Do window reset, ECM for 2 mins. Will I lose the seat memory?
Doing connect/disconnect when my 06 XK8 is in storage. I was hesitant to do on a 1-2 week basis but no problems for the past 2 months. Reset is simple. AGM battery steady 12.8. After a year of drains, no longer charges to 13.1. May hook to C-tek and see if that helps. Car always starts.
Old 06-28-2023, 09:32 PM
Stuart S's Avatar
Received 6,391 Likes on 3,501 Posts
Originally Posted by SeanU
You don't have anything plugged into the OBD port full time do you?
Originally Posted by CA Jag
Just the OBD wireless connect. ...
. That's the problem!
The following 2 users liked this post by Stuart S:
CA Jag (06-29-2023), SeanU (06-29-2023)
Old 06-29-2023, 06:27 AM
SeanU's Avatar
Yep... unplug it, and then do a battery disconnect and reconnect again!
CA Jag (06-29-2023)
Old 07-05-2023, 02:46 PM
CA Jag's Avatar
Thanks for the disconnect suggest. Improved to 13.1>12.5 over 5 days. Double click, info totally off, stereo off, headlights set to off. Full parasitic drain test next.
Drove the car 40 miles. Battery still 12.5. OBD charging shows 14.2-14.7. No warning messages. No codes. Checked voltage at terminals w/ car idling. It's 14.4 However, overnight charge w/ C-tek (4.3A max) and get 13.1. How can trickle charging work (12 hours) when driving 40 miles (1.5 hours) doesn't? Ac on, stereo on. Does it make sense to replace a 1 yr old high quality battery (done by PO) that trickle charges to full voltage?
Old 07-05-2023, 09:16 PM
Cee Jay's Avatar
Received 5,511 Likes on 3,242 Posts
Charging at 14.7 volts seems a bit high for a 'new and good' battery. I'd think there is a bad connection somewhere, either a ground point or maybe the battery cables on either end?
CA Jag (07-06-2023)
themorningman
03-01-2021 03:49 PM
clubking
08-09-2019 04:12 AM
JDog
04-04-2019 02:55 PM
Sidney365
02-09-2016 05:10 PM
chazaroo
02-08-2014 11:22 PM
Quick Reply: PLEASE - Is there Definitive Battery Guidance -2010 XK
