Plug and P0308
Canadacat (07-15-2023)
Put the plug back in but changed the coil. Plugs have less tgan 5000 on them. I guess i have to drive it and see if it comes back. I think it has something to do with my cat getting bad , might be back pressure affecting it on full throttle. Vacuum is constant at idle, think that is ok.
thx
thx
McJag222 (07-15-2023)
thx
thx
Might be worth sicking some injector cleaner in the tank just in case that injector is acting up a bit.
Tried, twice . Car has ran great even with the p0430 but niw going into restricted performance p0308 , might be a glitch who knows byt i know the catalytic has to go. Got a cheap one from rock auto coming .My car is basically a weekend car so don't require a 2000 factory catalytic installed.
Cee_Jay used some cat cleaner after an issue with a fuel injector I think. He said it worked. Might be worth a try if you think there is a cat problem. I bought some from Canadian Tire but haven't used it.
Because a faulty spark plug is NOT the only possible cause of P0308. Here's the relevant section from the Workshop Manual:
Although X150 uses extended DTC coding (1 Alpha + 4 Numeric + 2 Numeric), there are no extensions defined by Jaguar for P0308.
