Portable Audio Interface and iPod Nano 6G
Old 08-19-2016, 09:04 PM
buddhaboy's Avatar
Am I understanding this correctly, that a new, as in 2016 Ipod Nano will not work with a 2013 XKR? I have the correct panel and cable, but as i follow this thread I'm lead to believe software upgrades/changes nullifies compatibility.
Maybe someone with first hand knowledge could set me straight. Thanks.
Old 08-19-2016, 09:28 PM
Stuart S's Avatar
Received 6,383 Likes on 3,498 Posts
Since you have the OEM Jaguar cable, I suggest that you go to your local Apple Store and ask a salesman to test the new 2016 iPod Nano and the Lightning adapter to see if it works with your car. That way you'll know for sure.
Old 08-20-2016, 04:24 PM
Assure's Avatar
Default compatability
I have a 2009 XKR which I had a similar problem as the car was not capable of using the newer technology. What I found out was that if I used any memory stick up to 8G and I bought an older issue Ipod3 these work perfectly fine. Anything with a larger memory does not appear to work in my 2009 model. Hope this helps.
Old 09-01-2024, 04:01 PM
slb07jagxk's Avatar
Thank you!
King Charles
10-16-2015 01:25 AM
sdelliott58
09-28-2015 11:21 PM
Rocky15
09-28-2015 04:59 PM
42Ajd
09-26-2015 07:04 PM
Quick Reply: Portable Audio Interface and iPod Nano 6G
