Possible Fuel Leak?
Possible Fuel Leak?
Hello everyone!
It seems that my 2010 XK might have a fuel leak and I can't find the actual leak or cause. NO fuel spillage can be detected via visual or smell yet the fuel level display and range ticks down at a WAY faster than normal pace. I will lose about 6 extra miles on a 12 mile trip. Has anyone heard of any weak links or common issues with this year/model regarding this type of issue?
Appreciate any help as I haven't been able to find any information online so far.
Thanks!
Brian
Thanks!
Brian
Hello everyone!
Thanks!
Brian
Thanks!
Brian
Briguy1971 (02-14-2017)
Hopefully I have answers to all of your questions and I REALLY appreciate the help!!
My tail pipes do indeed have some black on them. I will try to attach a picture to this post.
Idle is normal and smooth. Coolant temp per Torque Pro via OBD is 188 degrees. No codes and I tend not to use the same brand or gas station when I fill up but I always use premium.
I’m not sure how to check for closed loop and I’m not sure what the proper fuel trim settings should be. I will post the test results below as well as the fuel trim results.
Fuel Trim Bank 1 Long Term: 7.81%
Fuel Trim Bank 1 Sensor 2: -1.56%
Fuel Trim Bank 1 Short Term: 1.56%
Fuel Trim Bank 2 Long Term: 7.81%
Fuel Trim Bank 2 Sensor 2: 1.56%
Fuel Trim Bank 2 Short Term: 2.34%
Test report:
MID:$01 TID:$82
- O2 Bank 1 Sensor 1
Max: 65.535 Min: 0.3
Test result value: 0.967
PASS
MID:$01 TID:$83
Max: 126Ohm Min: 0Ohm
Test result value: 39Ohm
PASS
MID:$01 TID:$9a
Test incomplete or dependant test failed
MID:$01 TID:$9b
MID:$01 TID:$9c
Max: 720ms Min: 0ms
Test result value: 420ms
PASS
MID:$01 TID:$9d
MID:$01 TID:$9e
MID:$02 TID:$85
- O2 Bank 1 Sensor 2
Max: 65.535V Min: 0.35V
Test result value: 0.962V
PASS
MID:$02 TID:$86
Max: 120ms Min: 0ms
Test result value: 20ms
PASS
MID:$02 TID:$9f
Max: 65,535ms Min: 10ms
Test result value: 2,490ms
PASS
MID:$05 TID:$82
- O2 Bank 2 Sensor 1
Test result value: 0.848
PASS
MID:$05 TID:$83
Max: 60Ohm Min: 0Ohm
PASS
MID:$05 TID:$9a
MID:$05 TID:$9b
MID:$05 TID:$9c
Max: 720ms Min: 0ms
Test result value: 409ms
PASS
MID:$05 TID:$9d
MID:$05 TID:$9e
MID:$06 TID:$85
- O2 Bank 2 Sensor 2
Test result value: 0.928V
PASS
MID:$06 TID:$86
Max: 120ms Min: 0ms
Test result value: 40ms
PASS
MID:$06 TID:$9f
Test result value: 2,670ms
PASS
MID:$12 TID:$cf
Max: 0 Min: 41,024
Test result value: 61,465
FAIL
MID:$21 TID:$88
- Catalyst Monitor Bank 1
Max: 15V Min: 0V
Test result value: 3.11V
PASS
MID:$22 TID:$88
- Catalyst Monitor Bank 2
Max: 15V Min: 0V
Test result value: 2.99V
PASS
MID:$35 TID:$a1
Max: 160° Min: 0°
Test result value: 71.27°
PASS
MID:$35 TID:$a2
Max: 11° Min: 0°
Test result value: 0.02°
PASS
MID:$35 TID:$a3
Max: 10° Min: -10°
Test result value: -0.86°
PASS
MID:$35 TID:$a4
Max: 10° Min: -10°
PASS
MID:$35 TID:$a5
Max: 160° Min: 0°
Test result value: 115.57°
PASS
MID:$35 TID:$a6
Max: 11° Min: 0°
Test result value: 0.64°
PASS
MID:$35 TID:$a7
Max: 10° Min: -10°
Test result value: -1.15°
PASS
MID:$35 TID:$a8
Max: 10° Min: -10°
PASS
MID:$36 TID:$a1
Max: 160° Min: 0°
Test result value: 70.88°
PASS
MID:$36 TID:$a2
Max: 11° Min: 0°
Test result value: 0.05°
PASS
MID:$36 TID:$a3
Max: 10° Min: -10°
Test result value: 2.29°
PASS
MID:$36 TID:$a4
Max: 10° Min: -10°
PASS
MID:$36 TID:$a5
Max: 160° Min: 0°
Test result value: 116.04°
PASS
MID:$36 TID:$a6
Max: 11° Min: 0°
Test result value: 0.5°
PASS
MID:$36 TID:$a7
Max: 10° Min: -10°
Test result value: 1.19°
PASS
Test report:
MID:$01 TID:$82
PASS
MID:$01 TID:$83
PASS
MID:$01 TID:$9a
MID:$01 TID:$9b
MID:$01 TID:$9c
Max: 720ms Min: 0ms
PASS
MID:$01 TID:$9d
MID:$01 TID:$9e
MID:$02 TID:$85
PASS
MID:$02 TID:$86
Max: 120ms Min: 0ms
PASS
MID:$02 TID:$9f
PASS
MID:$05 TID:$82
PASS
MID:$05 TID:$83
PASS
MID:$05 TID:$9a
MID:$05 TID:$9b
MID:$05 TID:$9c
Max: 720ms Min: 0ms
PASS
MID:$05 TID:$9d
MID:$05 TID:$9e
MID:$06 TID:$85
PASS
MID:$06 TID:$86
Max: 120ms Min: 0ms
PASS
MID:$06 TID:$9f
PASS
MID:$12 TID:$cf
Max: 0 Min: 41,024
FAIL
MID:$21 TID:$88
Max: 15V Min: 0V
PASS
MID:$22 TID:$88
Max: 15V Min: 0V
PASS
MID:$35 TID:$a1
Max: 160° Min: 0°
PASS
MID:$35 TID:$a2
Max: 11° Min: 0°
PASS
MID:$35 TID:$a3
Max: 10° Min: -10°
PASS
MID:$35 TID:$a4
Max: 10° Min: -10°
PASS
MID:$35 TID:$a5
Max: 160° Min: 0°
PASS
MID:$35 TID:$a6
Max: 11° Min: 0°
PASS
MID:$35 TID:$a7
Max: 10° Min: -10°
PASS
MID:$35 TID:$a8
Max: 10° Min: -10°
PASS
MID:$36 TID:$a1
Max: 160° Min: 0°
PASS
MID:$36 TID:$a2
Max: 11° Min: 0°
PASS
MID:$36 TID:$a3
Max: 10° Min: -10°
PASS
MID:$36 TID:$a4
Max: 10° Min: -10°
PASS
MID:$36 TID:$a5
Max: 160° Min: 0°
PASS
MID:$36 TID:$a6
Max: 11° Min: 0°
PASS
MID:$36 TID:$a7
Max: 10° Min: -10°
PASS
Should have a status value for closed/open loop etc. If OL it'll be bad mpg as it dare not do other than run rich.
Ignore MID/TID.
Trims, parked, hot engine, at idle & again at about 2500rpm.
You could out of curiosity also get a passenger to look when driving (or record data, if it will).
It's worth doing brim-to-brim fuel fills & hand calculate mpg as a sanity check.
Ignore MID/TID.
Briguy1971 (02-15-2017)
