Potential Differential Issue...
Well, it was bound to happen. I have a major issue with my 2012 Jag XK (5 liter, NA). I think it is driveshaft or differential-related. Here is the story ... any help is appreciated.
On driving home from work I began hearing a mechanical/metal creak (like a fatigued or stressed piece of metal as you hear in buildings like Chicago, in high wind.) That was 5 miles of stop and go. There was a little thunking in the driveline tunnel. I jacked the car up and tried to see where the issue was/is. I learned nothing.
Next day I drove it to work, thinking the creaking had to be suspension-related, but nothing major. Oh no...I should only be so lucky. I heard a horrible metal sound like splines of a shaft skipping or shearing. Of course, it could have been anything but it happened primarily on deceleration. I hobbled into the office, parked and began wasting my company's investment in me by thinking through the issues. I even contacted a fellow forum member (thank you, thank you, thank you Sean W for being available). We matched wits and decided it had to be the center coupler or driveshaft related.
I drove home and the noise became loud enough and violent enough that I was afraid the car would be disabled in rush hour traffic. Upon deceleration, the crunching, banging noise was happening so I put some throttle down and more pressure on the brakes - and it helped keep the noise at bay. It could have been coincidence but my goal was to put pressure on the driveline (which is when I didnt hear any noise) while coming to a stop.
Fast forward, shop has it now and after a day of looking it over, they think it could be the differential and the driveshaft. Am not feeling very excited about that. I have been searching the forum for similar threads but in the end, I will probably have to rely on the mechanic.
If you are still reading, I would appreciate any feedback you have on any known issues.
Car details are 95K on the clock (miles), tight and runs perfectly fine, no service history to refer to (I bought it from the original owner and, well, I sort of bought the seller not the car.)
So...assume that the diff was not serviced. Ugh.
There's two diffs for the 5l
The e-diff for xkr which is LSD and mechanical open diff for the n/a.
There's a member here that actually swaped out his open diff in his xk 5l for a V6 s ftype diff as it comes with LSD which is a straight bolt up according to him .
Received 1,123 Likes
All I know is that they are repacked and I have driven it about 15 miles without any hint of noise or issue.
I need to buy a lottery ticket. Or, ask Britney Spears out on a date.
steve_k_xk (05-15-2022)
guy (05-15-2022)
Just a quick follow up as I know there are different approaches to repacking CV joints @Speedmaster . Did they pack with the joints in situ? Eject via needle? Remove them and R&R the clamps? Finally how many hours did they charge/take for the job?
Sean W (05-24-2022)
Elizabeth Blake
09-17-2019 08:12 PM
Sshenton1975
08-30-2015 09:29 AM
