Power Supply recommendations for 07 XK when using SDD
And if you serch SDD power supply you find others.
While flashing modules and such, my pre-battery required was at maximum 35 amps. A person could probably run SDD with a 30 amp for a couple hours before it became an issue.
Also, going through a battery, the battery IS the filter. It takes out all the buzz and fluctuations out of even a cheap charger. Of course the battery has to be in decent condition regardless.
freeb1703
07-20-2024 02:15 PM
