Power Window problem
Try to reset the windows as follows:
Turn on the ignition. Start with the windows up and doors closed. Lower both windows and keep holding the buttons for 5 seconds after the windows are down. Then raise the windows and keep holding the buttons for 5 seconds after the windows are up.
If the problem resolves, then recurs again, your battery is probably low and needs a charge or replacement.
EscapedApe
03-19-2016 01:28 PM
