Pressure, Coolant, Battery Instruments for 2013 XKR
I did a search and could not find any reference to this topic.
I have a 2013 XKR and would like to know if there is a set of instruments to monitor this car's functions, oil, coolant, battery. I called the dealer and he said that Jaguar does not have any such thing.
Has any member installed such cluster and what have been the results?
Thank you,
cai
Thank you,
cai
See https://www.jaguarforums.com/forum/x...nstall-138621/
Unfortunately the HKS CAMP 2 is out of production, so you need to find a used one, or else use a cellphone with a video interface and this: Kiwi 2 OBD2 OBDII Wireless Diagnostic Scanner | Android and iPhone
You can also use standard aftermarket gauges, and mount them to the dash or A-pillar.
Thank you,
cai
Thank you,
cai
I've looked everywhere in the workshop manual and the wiring charts - I'm pretty sure there's no direct oil pressure sensor. I guess it is monitored indirectly by other sensors, e.g. the VCT sensors, because the variable timing is driven by oil pressure.
[QUOTE=Ngarara;1248989]I've looked everywhere in the workshop manual and the wiring charts - I'm pretty sure there's no direct oil pressure sensor. I guess it is monitored indirectly by other sensors, e.g. the VCT sensors, because the variable timing is driven by oil pressure.[/QUOTE
What I was trying to find was the location of the sensor that would give you a "low oil pressure warning". Usually there would be one around the oil filter location. It only reads in the 5-8psi range where if the pressure is below that a warning message comes up. It is more of a pressure switch which goes to ground if not enough OP. I gotta believe there is a port somewhere.
Thank you for the replies. I will look into both types of units. For the Kiwi, now with Windows 10 coming out, a small tablet could run all the telephone apps and thus have a bigger screen to view the data.
I could use the cigarette lighter to keep the phone or tablet chaarged and in the car all the time.
cai
cai
I use an OBD reader and the torque app on my Galaxy phone which I clamp to a center AC outlet with a clamp bought for that purpose on ebay or amazon - can't remember which. the mobile is plugged into the cigarette lighter. I get coolant temp, volts readout and several other pieces of information that can be changed as I desire. Only thing lacking is oil temp and pressure.
The more digging I do, the more I'm sure that the oil pressure is not monitored. In order to check it in a workshop, you have to install a 'special tool', number 303-1451, which is an adapter that replaces the normal oil filter housing. The adapter has an outlet to connect a pressure gauge - I assume you could fit something like a PLX pressure sensor that would integrate with the PLX Kiwi system (the Kiwi platform supports dedicated non-OBDII sensors).
cai
cai
Maybe not a given, but, if the oil temperature goes up does the coolant temperature also go up? Is the reciprocal true, that is, if the coolant temperature goes up does the oil temperature go up?
The issue about not having either reading is that one does not know wherein a problem lies. I am glad to see that others have the same concern and probably a solution, oil pressure measuring point, can be found. As Ngarara says, the measured value could be incorporated into the Kiwi readings.
I just ordered the KIWI and will post something next week as soon as I get it operational. In the mean time, I will also keep an eye and an ear open to any possibilities of incorporating a future oil pressure point into this unit.
I have not found the techs at the dealer too helpful so it is up to us to find a location for a transponder. As Jagtoes mentioned, I am also curious as to how the XKR racers are able to read their oil pressure and temperature.
Thank you for all your very useful information.
cai
cai
cai
cai
For the 4.2 engines, I make an adapter for the oil pressure switch port, which has rare and unusual threads: M10x1.25 .
See Jaguar V8 Oil Pressure Adapter - TheJagWrangler
The problem is I am not sure if there is adequate clearance for it on the X150. I do have one customer who was trying it and I will report back his results if I can reach him. An alternative is to make a custom adapter up using these turbo oil feed lines with banjo bolts which are also available in this size: Universal Turbo Oil Feed Line 40" M10x1 25mm Banjo Trusts TD04H T517Z T518Z | eBay
Unfortunately, on the 5.0 engines the oil pressure switch/temperature sensors have all changed, and I have not investigated compatible sizes yet.
kj07xk (08-17-2015)
I appreciate the observation Jagtoes.
Thank you.
cai
The GT3 car is based on a 2008 4.2, which does have a pressure switch, and I don't believe the 5.0 R-S GT has any different instruments. If the adapter is basically the same as a normal filter housing, it ought to be OK, provided the sensor is securely connected so there's no chance for it to come off.
