I've just got a genuine xkr-S carbon fibre one that I'm hoping will fit on my 2008 xkr.
The sides drop down quite a bit so definitely needs something to join against!
Does anyone know where I can get the two corner side spats/extensions?
I'm having real trouble getting the small fibreglass bumper spats/extensions.
I've emailed Chris twice. Couple of other places can supply copies but way overpriced for what they are.
Just want some at a reasonable price as will still have to have them painted.
Maybe I should have gone for the priince diffuser as it doesn't need these panels. I didn't realise the carbon fibre one had open sides and that wasn't cheap either! Ha ha
I installed a Priince Diffuser on my 07' XK a while back and it certainly changed the look of the rear. I also installed twin pipes so as to fill up the exhaust opening. Its relatively cheap to buy compared to others. Fitment was bang on and install very easy and completely reversible. Unfortunately I dont have a better picture. I had it originally painted the same as the body color but then went with black. I dont have a better pic to share, was quite foggy and overcast on the day of pic. Car was traded in 3 weeks ago for a brand new Corvette Grand Sport. Should have kept Jag anyway.....
Here is how it arrived. I chose to have it already in primer. If anyone considers doing a swap on an XK a swap to the exhaust tips is a must.
Looks good to me! Perhaps I should have saved some money and gone with that? My carbon fibre one still isn't on! Not bought the side spats yet. Target is for the summer as doesn't get used much in our winter 👍
The picture does not do the Priince product any justice. It fits very well and its an instant change to the stock look of an XK. I would recommend it from both a price point and look. But, I cant stress enough that for the XK owners twin pipes are pretty much a must.
Install was simple. It requires the removal of the existing rear fascia panel. Its held on by (I think) 10mm bolts and some metal 'holddown' clips which I removed with a pointy screwdriver. The Priince diffuser mounts using the same hardware onto the stock mounting holes. I have a lift so its a bit easier to do rather than jacking up the rear. I would say that once on the lift, the removal and placement took 15- 20 mins.
Here are some pics .I cant tell you the cost as yet mixed up with deal package , I spoke with chris he said to give him a call , he is only making them to order.
Hi im interested in the full diffuser and side pieces. Can you link me up him. I'm based in South Africa 🇿🇦 Jhb
