Problem with top
Problem with top
I had to make a small repair to my top with the top partially open. When I went to put it fully down, nothing happened. I ended up putting it down manually using the allen wrench for the pump. I went through the reset procedure, but it didn't work. I decided to manually put the top up, but halfway there, it froze and now will not go back down nor will it reach the front latches. When I try to use the open/close button, I do hear a very soft sort of whirring sound. Any ideas on what to do? I can't drive it to a mechanic with it this way.
XJR100orXKR100
03-12-2015 12:10 PM
