Problems with convertible top on 2007 XK
Old 09-21-2022, 06:31 PM
optomeyes's Avatar
Check that the divider panel in the trunk is properly seated. If it got knocked out of position, the roof mechanism will not work. Make sure it is vertical and properly seated at the base of the divider.
Old 09-21-2022, 07:19 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Originally Posted by britishracer
PULLED ON THE CORD NEAR THE HYDRAULIC PUMP
Hi Forum,
I recently had problems with my convertible top. While investigating what was ultimately low hydraulic fluid in my pump, I stupidly pulled on the small pull cord near the pump and now I cannot get the top to operate. I get the message "Top Unlocked". Can anybody suggest a way to correct the situation?
Patrick
That small pull cord releases the tonneau cover. Press around on the front and side edges of the cover, see if you can get it to re-latch.
Old 09-21-2022, 10:13 PM
britishracer's Avatar
Is that what this pull cord is for? When the problem started the top was raising with difficulty and I could hear the whining noise of the pump that didn't have enough oil to operate. But now nothing works at all. I get the "top unlatched" message in the dashboard information window but the pump does not engage. Nothing happens.
Old 09-21-2022, 10:14 PM
OK I will try that tomorrow.
Old 08-04-2023, 06:01 PM
StanS's Avatar
Default problem with conv. top function - HOOD NOT LATCHED. it seems as electrical problem.
Have anybody electrical scheme for XK 150 MY 2007 ? I cannot find it.
Old 08-04-2023, 09:18 PM
kj07xk's Avatar
Received 1,975 Likes on 1,326 Posts
There’s a sticky at the top of this forum with the electrical guides. Select the one which includes your VIN.
ralphwg (08-05-2023)
Old 08-04-2023, 09:21 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
See the Sticky Threads at the top of this Forum and scroll down to the XK/XKR Workshop Manuals & Electrical Guides.
  #28
Old 09-06-2023, 02:38 PM
James Alexander's Avatar
Default Battery replaced now stopped3in up no nothing
Battery replaced went to put top down thing unlatched windows down and top started to move up from windshield 4 inches and stopped. Now nothing
tried to relieve pressure on pump. Still couldn't overpower the top.
While messing with pump i noticed the pump was really hot. Fluid level looks ok.
Your ideas please.
Old 09-07-2023, 07:45 AM
Default 07 XK top stopped on way up now nothing.
Originally Posted by Cee Jay
I'd say your pump is on the way out. Ten-Eleven years of year round usage several times a day can take its toll. So would a few times a month.
cee-Jay.
Had battery replaced . Put top up prior to new battery. R&R battery job comp. Went to drive car home oh well lets put the top down. Windows down windshield unlatch and top moved up 3-4 inches and now nothing. 07 XK. ???
  #30
Old 09-07-2023, 08:25 AM
WhiteXKR's Avatar
Received 2,985 Likes on 2,124 Posts
Front windows need to be reset after battery change for top to work properly. See owners manual or other threads on the subject.
canvasman (09-24-2023)
  #31
Old 09-07-2023, 08:47 AM
v8deuce's Avatar
About 10 posts back from your is a description of how I reset mine with the drivers window switch reset it worked for me although it took a few tries.
Randy
  #32
Old 05-10-2024, 01:31 AM
Geosnooker2000's Avatar
I'm having a problem I haven't seen anyone else complain about. When I try to lower the top, it "tries", but it sounds like whatever latching system is in the top of the windshield frame will not let go of the ragtop. It goes click, click, click, click, like some gear is stripped out or something. Is there a way to get it to manually unlock from the windshield frame?
  #33
Old 05-10-2024, 07:07 AM
kj07xk's Avatar
I suspect you do sort of the reverse of the manual reset procedure in the owners manual and use the allen key to release the overhead locks.
  #34
Old 05-10-2024, 10:19 AM
slick.one's Avatar
Hold the "top down" button for a 10 count and it will continue to lower.
  #35
Old 05-13-2024, 10:19 PM
Thanks I will give it a try!
