Programming Extra Key Fob with Tesla Android screen
I lost one of my Key Fobs. So I buy one online and I visit a locksmith and he told me the car doesn’t recognize my key because I have new Radio. He told me that’s it’s a antenna for fob in factory radio. Anyone have same problem or similar. Can’t sell my old unit😂😂😂
Take your XK to a Jaguar dealer to determine if that used Smartkey can be programmed to your car. Also bring your wallet.
Read this entire 2016 thread about Smartkeys:
https://www.jaguarforums.com/forum/x...ion%85-171095/
The cost of these things is crazy. When I go to buy a used Jaguar, I'm buying the 2 Smartkeys - the vehicle is just the sweetener to the deal.
Stuart S (08-05-2022)
Okay then... Once upon a time I lost a key so I bought a new one and had new and the one I already had programmed. Cost a bit. Three days later I found the other key. Of course it didn't work.
SO, since it wasn't divorced FROM my car, but it still WAS programmed to it, I assume it is still not programmable to the car (again).
Has anyone tried this? Reprogramming an original key after adding two other keys separately?
You bought a key online... I notice that you have a 2007 model year. The most important thing I learned from the thread referenced by Stuart, was a little snippet by u102768 referring to the key FOB part change:
"according to the parts system the change point was VIN B12815 which is part way through the 2007 MY."
The older vehicles (mine) have a single channel FOB. The newer ones have a multi channel FOB (like probably most sold on the internet). The dealer that eventually fixed my problem did not even know this.
Last edited by 007XKR; 08-05-2022 at 04:15 PM. Reason: clear up confusing verbiage
When adding additional keys with SDD, any previous fobs which were already paired with the car MUST be present when adding fobs otherwise they will no longer work after programming the new fobs and I'm fairly certain used fobs must have been unpaired from the previous car prior to pairing to a different car. JLR's next generation fobs did not have this problem and it's much easier to add old keys from other vehicles to new vehicles (I've swapped fobs back and forth between vehicles).
I have programmed keys to my car using SDD. You must have the current keys present and I tried another used key and per the divorce details it did NOT work. My then current key and my brand new one paired together and both work.
This I think was 2-3 years ago but I recall it being programmed to the cluster or related computer, not anything head unit related.
