Programming Key Fob 2008 XK
I have read all the information I can find regarding programming the fobs and every one starts with placing the steel key in the ignition. My car doesn't have an ignition switch but rather a slot in the center console where one places the entre fob to start the car. The only 2 slots for the steel key are in the door handle and the boot. Is it still possible for me to program the fobs or must I go to the dealer?
Thanks for your help.
You're correct Ralph. Synrgy, per the repair manual:
"If a replacement Smart Key is required, 2 Integrated Diagnostic System (IDS) diagnostic procedures are required to synchronize the passive start/entry and transponder functions of the Smart Key. If any module, which is involved in the Smart Key authorization process, require replacement, an IDS diagnostic procedure is also required to synchronize the replacement module into the system."
synrgy (08-16-2016)
many Jag specialty indi mechanics have the software needed to reprogram your key, call around as that may save you a ton of cash... also pray that your key CAN be programmed as many sold on eBay and other venues cannot be.
Read the owners manual (free on this site) regarding that center fob receptacle - that's there only when things get out of whack occasionally so the car can get reacquainted with your fob not actually reprogram it otherwise your car is keyless so it shouldn't ever need to be taken out of your pocket.
synrgy (08-16-2016)
If the fob isn't unlocking the doors putting into the slot won't help you. Make sure the battery is good (new doesn't mean good respect if it's not a good name brand) and maybe try cleaning it out with electrical contact cleaner and running alcohol before investing $75-200 in reprogramming
If the above doesn't work, make sure the battery in the remote is making good contact inside the housing. I've read on other threads that the spring contact can become bent and not make a connection with the battery, resulting in a 'dead' fob. Bending the contact a little bit solves that problem.
