Promising Valve cleaner and injector cleaner
#41
You will only be able to see the condition of the top of the piston and the bottom of the valves then. The carbon buildup on GDI engines occurs mostly on the intake side of the valves.
#42
Am thinking of doing this on my XJR non DI engine just to check and see if my meth system works the way I want it to.
#43
I understand that. The endoscope has a mirror allowing a sideways look. So if the valve is in the fully open position I would think that I could see the back of the valve?
Just make damn sure that mirror attachment is on nice and tight!
#44
#46
John why do all that.
You know as sure as the sun will rise you have carbon, you have carbon on the injectors.
I can tell by your signature you are into the last ounce of performance and perfection.
So you are going to most likely be cleaning often, not just what you have now under the rug.
The hole is the best idea because it will make all subsequent applications easier without the risk of breaking connectors.
Shame you have a tune because there was an easier way of knowing if you have power robbing carbon- just dyno the thing.
#47
The above is a Range Rover 5.0 cylinder head on Ebay.
#48
https://www.ebay.com/itm/2010-17-LAN...0AAOSw3x9cuREf
Oooooooookaiieeee??? I don't know what you're trying to say...
#49
You are correct about the carbon build up for sure I think. However I have nothing to lose with using the endoscope and I will have before and after pictures to see whether
the CRC actually works.
I undid the VAP tune when I had suspension problems thinking incorrectly it affected my suspension. I have 2 different VAP tunes btw. Mice were the problem and they have been dealt with along with the air pressure tube they gnawed thru.
George05 (11-08-2019)
#52
Seeing the condition of a valve face is worthless.
inside intake runner..........
#53
One of our vehicles is a 2015 Discovery 4 with the SC V6. For sometime it has had an issue with consistently running rough when the AC is turned on or when turning the steering wheel or running the suspension compressor. Dealer had suggested possibly needing a new AC compressor and suspension compressor as they supposedly performed a high priced intake/induction service with no success.
So today I picked up a can of this CRC GDI intake cleaner and decided to give it a shot. I used the breather on the top of the throttle body and followed all of the steps.
Well I’m stunned. This stuff completely cleared up the problem. Motor runs smooth and quiet like it did when it was new. For 20 times less than the cost of the dealer intake service and no parts to replace it’s like a new truck.
Thanks for sharing this product with us. Now to do the 5.0 liter SC Range Rover, which does not have any running issues but I’m sure will benefit from this.
The following 7 users liked this post by jahummer:
guy (12-21-2019),
jackra_1 (12-21-2019),
pwpacp (12-21-2019),
Queen and Country (12-22-2019),
ralphwg (12-23-2019),
and 2 others liked this post.
#54
Per this pic, see the yellow mark smack in the middle of the pic where I have disconnected the line, the line then snakes around the side of the SC then the back of the SC and plugs into a nipple low down on the LHS of the SC:
#55
Yep, I just checked the brake booster vacuum line on my V6 F-Type and there is a real easy to access join in the line that can be disconnected, so that is where I will try.
I used the brake booster vacuum line connection shown above and it all went without a hitch.
I also used two of the clear plastic tubes that came with my oil extraction pump joined together, that way I could spray the contents of the can into the brake booster vacuum line while sitting in the driver's seat operating the throttle. I can't find who it was that suggested this method (they bought six or nine feet of 9 mm clear plastic tubing) but thanks for the tip! The thick end of the pump tube fitted perfectly over (not inside) the brake booster vacuum line tube with a nice tight fit, and the spray tip of the can of CRC fitted down the other end of the thinner tube just nice.
Took seven or eight minutes of regular on/off spraying to empty the can of CRC and about six minutes in the check engine light flashed up for about three seconds then went away. And during the one minute of idling afterwards the top of the engine sounded very rattly and a different rattle to what I have ever heard before (and mine has always been a very rattly engine).
I was worried that the CRC treatment may have done some damage to the SC, and when I took the car for the recommended 10 minute highway run (after shutting it down and letting it heat soak for an hour) it hiccuped very briefly the first two times I gave it WOT. But then it came good, no more hiccups, plenty of power and no CEL. Maybe it was just coughing up some dissolved carbon build up?
Too early yet to tell if the CRC treatment has made any discernible difference but it feels at least as strong as it did before.
The following 4 users liked this post by OzXFR:
#56
#57
I really doubt the CEL could have been due to the disconnected brake booster vacuum, it came on only once for about three seconds while the brake booster vacuum hose was disconnected the whole time.
#58
Have you seen their test results showing long term cleaning effects?
Mind you I have seen their dealer training video where they do 2 applications back to back, also same of BK44
#59
I assumed that one if the advantages of GDI would be clean intake valves as there'd be no evaporated fuel deposits on them, so can anyone explain why clean, filtered air passing over the valves leads to carbon build up like this?
#60
Specifically 2.44 to 2.52 of the vid.
