Proper battery for 2012 XKRS. AGM or not?
#41
I have no idea what you mean by 'XK lifestyle'. Kill any battery? I thought you said earlier you couldn't kill an AGM battery? I also believe that charge depletion by multiple short runs is primarily a function of battery capacity, not type. Additionally surely an AGM battery can only charge faster if the charging system recognises it and can cope with it which it will not do if it is not optimised for AGM batteries. As to undercharging, my understanding is that surface charging is much more of a danger than allowing a battery to be depleted fully then fully charging it.
XK lifestyle= infrequent usage= greater discharge than charge- namely due to extensive electronics and greater crank amp demand, so former Jags are different animals.
Speed and rate of charging is not function of the charger rather the batteries chemistry, i.e ability to absorb the charge, i.e resistance.
You cant kill an AGM battery because its warranted for 5 years and more. In other words, it will always be under warranty.
No, warranty on batteries is no joke! ask Samsung or Apple. There are no loopholes. If you get a 5 year replacement battery it means they have to standby it. Also ask Jaguar they were sued for their battery system.
Others here will tell you that flooded batteries corrode. Its the blue and white powder you see on the terminals.
#42
#43
#44
The following 2 users liked this post by pwpacp:
QP7 (10-10-2023),
Queen and Country (05-21-2018)
#45
#46
#47
To muddy the waters guys, many XKs have replaced their batteries with a larger group 48 model battery. Correct me if I am wrong!
My hypothesis is that such a move makes, the alternator "somewhat too small" for the larger size battery. Flooded or AGM. So keep a maintainer nearby, and use it when needed.
#48
Received 2,011 Likes
Depends on the AGM battery. Some do, some don’t. If it has a vent hole, use it (may have two holes, in which case the unused hole should be plugged). AGMs are less likely to vent gas, but since our battery location is in an enclosed space, better safe than sorry, use the vent.
#49
is there any other method to determine if a car was originally designed for a flooded or AGM battery?
#50
I did't realize they were vented either but hey, learn something new every day. GGG once wrote that, in conversation with someone @ JLR (or Dealership), the AGM batteries were fitted on the start/stop models. Maybe he can confirm for you but that works for me.
#51
Received 1,123 Likes
@XKDreams , yes.
Look at the appropriate workshop manual for your vin. The specified battery will be listed there under “Battery / Specifications”.
If you cannot locate the appropriate workshop manual, the Jaguar parts counter can look up these specs for you. Those lookups are also based on vin.
Cheers.
Cheers.
#52
Received 3,225 Likes
Originally the S/S system had two batteries, a big one and a smaller "auxiliary" one both AGM, then around 2016 they switched to a single battery system.
Sean W (06-11-2024)
#53
@OzXFR , I have the 2 battery solution in the LR4. It works perfectly. And I think the engineering is sound; use the aux battery for monitoring while engine and charging are off. Reserve the “big” battery for the “start” operation.
I have wondered why this good solution needed to change to the single battery approach.
Cheers.
Cheers.
#54
Cheers.
Cheers.
Gotta be cheaper than two batteries and less prone to breaking down or either battery going flat.
Either way doesn't bother me in the slightest as the F-Type is the first and only car I haver ever owned with S/S and the very first thing I did when I got the car home (nearly eight years ago now) was to permanently disable the damnable thing!
jahummer (06-11-2024)
#55
sony2000 (06-12-2024)
#56
I am enjoying this thread. I have a 2021 and a 2015 BMW 3 series and when changing the battery one has to reprogram the battery monitoring system with a special scanning tool. This allows one to specify the type of battery (useful if one switches from conventional lead acid to AGM, etc) and the CCA rating of the battery. I have read that Jaguar has a similar scheme for their late model cars, including the XK. I think that this allows one to use either type of battery.
abonano
05-12-2012 02:47 PM
