PSA: Replace your 2 piece lug nuts
I'm more a fan of this one. I prefer to bar to be 90 degrees to the wheel. Regarding the sockets Q&C mentions, I believe they help preserve the wheel paint but don't think they protect the lug nut?
https://www.amazon.com/dp/B00JFH6D1E...v_ov_lig_dp_it
I was just considering this one till Sean posted a tempting option.
https://www.amazon.com/Neiko-03970A-...e%2C158&sr=1-3
Queen and Country (07-08-2019)
Yep, I like that one too. 24" of leverage should definitely break any nut loose. Another advantage of that one is that you can use your jack under it if needed, to gain advantage of the weight of the car to loosen a frozen lug nut. Right now I just have a 1/2" breaker and socket.
... Also buy one of these and keep the 19mm socket in your glovebox. For one it will prevent wheel from being scratched up, but its a polite way of making sure the pimple faced dummy at the tire shop knows what socket size to use.
https://www.ebay.com/itm/3Pc-Thin-Wa...cAAOSwa1ZcUL-1
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1077x1355/screenshot_20190709_064214_chrome_51d2f398adaa4d49c8c9df19c2304f01f974729f.jpg)
Cee Jay (07-09-2019)
I agree; you definitely should keep a 19mm socket in your car. But why pay $13.99 for a 3-piece set with 2 sockets that you'll never use when you can buy this and save $10 (or more with a store coupon)? I'm fortunate to have a Harbor Freight store close by. Otherwise, buy it online.
Stuart S (07-09-2019)
#28
That's the socket I have! I also have a torque wrench in a case right next to the spare.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1072x654/screenshot_20190709_185124_chrome_2e4838c22f1d0cb6e8227b583bf09be8f7dfd7b6.jpg)
It's still the same price.
#31
Received 1,103 Likes
it seems some having issues with the engineered solution, didn’t follow the rules;
1. do not use an impact gun
2. use the appropriate metric socket
3. torque appropriately.
I always “break” the initial hold by using my 1m breaker bar. No issues whatsoever.
incidentally, the wrench in the boot is for emergency use, not continual maintenance use. I wouldn’t expect the hollow handle to take the abuse of continual usage.
Maybe a little anti-seize on the threads as well. I tend to rotate tires every oil change for my vehicles. It is not bad practice to remove wheels and inspect brakes, etc every 3K-5K miles. This way you are less likley to be in a situation where the lug nuts are completle frozen from not being removed in decades. I still stand by the one piece solid lug nuts as the 2 piece tend to deform. I have experienced this on other vehicles, but due to the wheel style was able to easily remove. The Jag and Senta wheels and deep cavity of lug hole area seemed to introduce more difgficulty in trying to remove the cap portion of the lug nut to get to the actual threaded part.
#34
Received 1,975 Likes
guy (11-03-2021)
#35
Based on this thread and others, I became fearful of being stuck on side of road- unable to change a flat. So I did an inspection- each lug nut, one by one- removed, inspected, and a touch of anti-seize on each one before installing to spec. Here is what I found. They were all perfect, I great shape, and looked very well-built and sturdy. In other words the PO’s of my ‘09 Portfolio always did the work right (or had the tire work done by pros). Also, I have placed a 19 deep with beekeeper bar in my trunk so I don’t get caught. Thanks to all for the heads up.
#36
that was over ten years ago, and i still have this one tube of it, more than half full probably. pretty sure it affects torque reading but just go 3-5 pounds over spec and you're good.
