Quality of Jaguar Wheel Centres
I'm looking to replace my original factory fitted wheel centres with some new ones. My centres are black and show the Jaguar logo above a jaguar head.
I would like to get the same centres, but in red.
There are a lot of these advertised on eBay, some very cheap and described as "stickers", so I assume these stick on top of the existing badge, but others are described as original OEM and are priced from around £24 for 4.
I've also seen them advertised by Adamesh on their website, for £30, but this increases to £35.50 when you add postage. I was all set to purchase a set from Adamesh, thinking I could be sure of the quality, but then they went and added the £5.50, which is taking the p*ss. I know it's not much, but these things will fit into an envelope and I already decided £30 was more than enough!
So, what's the difference between the Adamesh centres and these on eBay:
Adamesh
eBay
Anyone bought any wheel centres from eBay? Are they okay?
How do they compare to those purchased from Jaguar, which seem to be extortionately priced?
I don't mind paying extra for an item if it is better quality.
Adamesh
eBay
I agree, they have to be packaged okay, but so do those badges sold on eBay.
There may be a material difference between the badges sold by Adamesh, eBay and Jaguar, but I'd like to know what it is before spending £77 for a genuine Jaguar part or £35 for an Adamesh part both of which may be exactly the same as the £24.99 eBay part!
Looking at the wheel centre badges on my 2007 XKR, they are just plastic with a design on them, so nothing special!
Based on past experience, I would "not" buy the stickers. Since the center caps are somewhat curved, the stickers do not fit flush against the center cap. They end up having a small crease to the sticker when applied, as they are made for flat surfaces.
Ebay is the best source. Many wheel center caps are plastic that has a Jaguar logo or emblem. When inserted into the wheel center, you can not tell if they are metal or plastic. Plastic caps are usually low priced and easy to source, and it necessary they can be replaced a cheap, low price.
I purchased stickers from overseas and they were a waste of money and time. They didn't fit properly.
Richard in New Mexico
Received 1,975 Likes
I bought a set like that off ebay. The quality is fine and they were packed in individual plastic bags to prevent scratching each other, and also bubble wrap to keep them safe.
Haven't used them, as I found a different style (probably older) that matches my paint color better (radiance red).
I had purchased a set of red caps from ebay to replace my black ones. They were cheaply made and although they snapped in they were a little loose. I also noted after a year the red started to dull out until finally I just took them off and put the black ones back on. I did look at the OEM red ones when I was at the dealers and you could see they were a better quality product. So either buy a new set every few years or buy the OEM's . Just my feedback.
I replaced black ones that had the same problem. I don't know if they were original OEM but they were also plastic and seemed the same quality as these.
Are the OEM caps metal?
They're red, but I'm hanging on to them to use with my Carelia wheels (the other new ones went on the Sentas now on the car), when I put the Carelia's back on to use up the almost new tires on them (for some long road trips).
Sean W (03-08-2017)
JAGUAR 4pcs. NEW X TYPE S TYPE XK8 XKR XJ8 WHEEL CENTER CAP RED LETTERS | eBay
I don't recommend them as mine are showing deterioration within 6 months (and I use Sonax wheel cleaner which is supposed to be one of the safer cleaners)....
I looked mine up and I paid $15.99, not $25 like mentioned above.
I would suspect all of the items found on ebay around this price are all from the same manufacturer though. So buyer beware. Maybe I just got a bad batch...
Sean W (03-08-2017)
I bought from seller "oldfai831" 2 years ago. Just checked the seller's ebay store, and there are none listed at this time. Back then, I only paid $8.70, plus $2.00 shipping.
Now the other ones I bought, also 2 years ago, and am currently using, were a bit pricier, $69.95:
Jaguar Wheel Badge Set - Center Cap - Wheel Motif - 1988-2012 - Maroon/Silver | eBay
Sean W (03-08-2017)
I bought from this vendor:
I sent a couple of emails to Adamesh earlier this week and I know they have been read as I got a read reply, however, I haven't received any response regarding my questions about the quality of the centres.
I'm a firm believer that if a business doesn't make the effort to communicate during the pre-sales process they are likely to be completely ignorant when it comes to their post-sales process and should therefore be avoided. After all, they make their money by selling goods and if they don't answer my questions they won't get a sale! Clearly, this isn't an issue for them.
Consequently, I have taken a gamble and ordered what are described as "Genuine Jaguar Wheel Centre Badges" from eBay. The photos do seem to show the correct markings, but I guess time will tell if they really are genuine or not.
The aftermarket ones are garbage, you can spot them as the back side of the cap is plain plastic, whereas the genuine ones have part numbers and other info moulded into them.
The aftermarket ones fall out after a while (lost a couple), or they fall apart; I've had the metal cap separate from the plastic on a couple leaving me with a pain black cap.
You get what you pay for, the genuine ones aren't cheap but they are worth it. I've had a set of genuine ones on for 2 years now, still look like new.
Sean W (03-10-2017)
SET of 4 Jaguar XF, XJ, XK, X & S Type BLACK GROWLER CAT CENTER CAPS | eBay
