Question on lug nuts for 2007 XK w/ 19" wheels
Hi all. I am useless mechanically and do not wish to try taking a lug nut off the 19" OEM wheels of my '07 XK. I need to order replacements (4, one for each wheel) for the locking nuts the previous owner put on but lost the key to. Can someone tell me what "seat" I need to order: acorn/cone, mag, or ball? Does it matter? Anything else I should know or consider? Thanks!
If you have the OEM alloy rims you should be ordering the mag lug w/ washer.
Here is an example I came across:
locking lug nut set / c2c9198 | eBay
The lug nut size is M12 X 1.5 - for a good cheaper option look into the McGard Wheel locks - they make a OES equivelant set for the Jaguar vehicles w/ the intergrated metal washer - I use them on my alloy rims with no issues. Hope this info helps.
pabanker (09-22-2012)
Hey hey! Finally found someone who sells the OEMs! I guess that'll do.... Should be cheaper than buying them through a dealership, no?
2007-2012 Jaguar XK Lug Nut - Original Equipment - Auto Parts and Accessories - Shopping.com
