Question on strange downshifting. Normal?
Just bought a 2007 XK with 25,000 miles. Love it! But whether in Drive or Sport, when I coast to a stop, or coast down a slight grade, the transmission automatically downshifts through the gears as the car decelerates. Is this normal? I'd prefer it didn't, at least not in Drive (the costing downshifts hurt fuel efficiency). I figured the transmission would leave it in the original gear until I either approached a full stop or touched the accelerator again (like what you do in a manual.)
Come to think of it, I don't like it in Sport either, because it means I'm not in control of gear selection!
Is this normal in everyone's XK?
Received 2,263 Likes
That is not the proper way to drive a manual, either. I hate people who drive that way. Especially when they are trying to drive in a spirited way. Downshift using heel-toe into a proper gear as you slow down!
Then again, this might explain why my fuel economy is so bad on my manual Mustang.
Mikey, it hurts fuel economy because when you're in a lower gear your car decelerates faster. My transmissions behavior means I spend longer on the gas before approaching a stop, or not coasting as quickly down an incline that wouldn't call for braking, etc. It also means more wear for the transmission, also a concern. It's very strange.
My S-type changes to lower gears as the car slows, readying it for acceleration as soon as I touch the gas, but actual engine braking is negligible. To achieve this, I have to manually select lower gears on the other side of the J-gate.
If you are feeling distinct deceleration with each downshift, then it sounds like the torque converter lockup might my acting weird. Either that or the transmission has learned some strange driving habit from a previous owner. Either disconnect the battery for a while or get your dealer to reset it.
That said, the 6-speed ZF does not coast/sail quite like a GM transmission. Even so it is unlikely you are using any extra gas as the overrun fuel cutoff is pretty aggressive on most cars these days.
pabanker (08-06-2012)
abonano
25
09-25-2015 10:43 AM
