radiator splash shield removal help
In the front wheel wells, there are two Torx screws on each side that hold the little flaps at the bottom front of the wheel openings. Have you removed those screws and the flaps?
After you have done that, you should be able to pull the splash shield towards the rear of the car, then it will drop down. The leading edge of the shield fits into a slot in the body, so you have to pull it out of that slot, then it can be removed.
Adding to what Patrick said...
There is a small round "latch" on the very front just to the right of center that is inline with all the front screw you removed. Sometimes you must "unlatch" that before it will slide backwards. So if it feels like it is hung up on something at the front edge and will not slide rearward and you are positive all of the front edge screws are removed, take a look at that.
Dave
Dave
Patrick Wong (04-26-2018)
Could be a 10-up thing, but check when you can. It is approx 3" to the right of the center screw. Just in front of the recessed screw/bolt in that area.
Dave
Wait, here is a quick pic..
BTW, I didn't do that scuffing on the bottom, was the PO. Going to be fixing that soon as bumper cover repaint by PO is not exact.
Patrick Wong (04-27-2018)
barnter
10-02-2010 11:51 AM
