Radio activation code
Hi,
Having just upgraded from a 2004 XKR to a 2008 XKR & checking through all the paperwork & documents I suddenly realised I have no code to reactivate the radio after battery disconnection as I did with my previous X100.
I can find no mention of it in the handbook so do I need one in the UK, if so how do I go about getting it.
Thanks for your assistance.
JonWat (12-01-2016)
JonWat (12-01-2016)
jahummer (07-20-2023)
ACTUALLY, isn't the .... I'm guessing here, the TSD is the display FOR the 'radio', but isn't it controlled by something else? Wouldn't that 'sound module' or whatever have a VIN in the firmware? I don't know, so I ask. Course if the TSD actually IS the sound system, I guess there isn't any code. I've never thought about it before.
Richard
Any consideration of programming replacement components for compatabilty is a completely different topic not relevant to the theft deterrent purpose of radio security codes.
Cee Jay (07-17-2023)
I thought I'd made it clear in post #2 seven years ago but I'll repeat that the X150 audio system does NOT have a radio security code for owner input after a battery disconnect/reconnect.
I was concerned about needing a radio code in the case of power interruption when replacing the battery.
I am planning on using a NOCO Genius 10 in 12v supply mode (not charge mode) to supply power to the car during the battery change. Either that or I will use another battery to power the car.
Thank you for the clarification.
GGG (07-18-2023)
X150 is the Factory Code for the 2006-2014 XK model.
We use the Factory Codes on the forum to distinguish between similar named models. For example, XKR could be the earlier steel bodied 1996-2006 XKR (Factory Code X100) or the later aluminium bodied 2006-2014 XKR model.
The XJ badge is even more confusing with five different models produced between 1968 and 2019!
McJag222 (07-18-2023)
Worth a slight diversion from the topic to explain this model naming convention.
GGG (07-18-2023)
