radio antenna
Hi everybody
i'm in this forum and an recent XKR 2007 owner. So at this moment i'm fixing some minor issues and at same time discovering the car.
anyone can tell me why my radio antenna doesn't close all after car stop. Antenna still open ( mast, chrome part still out about 15 cm) after car power shutdown.
Any ideas..can be an malfunction?
Failure of the antenna mast either to retract or extend fully is almost always caused by dirt on the mast. Extend the mast electrically, and clean it, wiping upwards (!) and then apply silicone spray lubricant (sprayed on a cloth, wiped *upward* on the mast. This process should be done at least twice a year.
The following 2 users liked this post by sov211:
Paulo Sérgio (06-30-2020),
Sean W (11-15-2020)
Received 1,123 Likes
Paulo Sérgio (07-04-2020)
I have fixed this issue on many electric aerials in this way. The segments get "frozen" by dirt and corrosion. Once you break the adhesion and properly lubricate the segments it will extend and retract propery. These aerials, properly cleaned and libricated periodically, last for decades.
The following 3 users liked this post by sov211:
Paulo, this may or may not solve the problem permanently. I continued to have an issue with the mast not withdrawing completely after many efforts to clean and lubricate it. The mast would act properly for a day or so after the clean/lube and then stop fully withdrawing again. I finally pulled fuse #4, which powers the antenna motor (fuse is located in the panel between the back seats), since I don't listen to the radio in the car, just stream music from my phone.
