Rattle after warm up and D shifting when car is stopped
Hi all. Cant find information about this, so I decided to made this post. After car is warmed up and switching Drive on selector and brake is still pressed, somwhere in engine bay or under the car is rattle noise. It appears only on D when vehicle is stopped, and continues about a mile and then disappears. Sooner I will add audio of this noise.
(XKR 2007)
(XKR 2007)
There is two recordings of this sound inside and outside the car (another question is: is your car in convenience mode make such humming noise too?)
jahummer (10-12-2021)
I don't hear anything unusual either.
EDIT: Sorry was having issues with the a audio player and it kept playing the same file which sounds just fine. Managed to get both files to play and it's hard to tell but could be a heat shield. Do you have a helper driving while you record?
About another recording: I just opened the left door and put the phone under rocker as far as I could.
And off top about convenience mode. Is your car make such sound or mine is wrong?
I'm the only driver of my XK so seat and steering column adjustment never changes - I don't use the entry/exit mode. Convenience therefore only activates interior and exterior lighting, message centre and power socket, all of which are silent. If you do use entry/exit mode then I'd expect the noise from the steering wheel motor and seat motors to be audible.
Im novice to the forum and not so clear understanding how to use it.
So I got another question: is there some threads like this noise is okay/this noise is not okay about x150?
Because I own car almost one year and not perfectly acquainted with what noise that XK makes is normal and interested to prevent it from damage and keep calm when I hear some weird sounds.
And thanks to all for reply
Received 2,011 Likes
I'm not sure that I understood You and not sure if you got me right.
Talking about buzzing sound around the dashboard when car is opened and waiting to startup. It only disappears (with click)after 30 minutes of waiting without starting up or ignition on or when car is closed from outside.
XK 2007 Knock sound - RESOLVED - Jaguar Forums - Jaguar Enthusiasts Forum
In your under the car sound, I think I hear something very similar to a knock (more like a dink, dink, dink sound) I have been chasing for almost three years on my XK 2007. It turned out to be a warped flex plate. Here's the thread I recently posted, you'll find audio of mine there.
I recorded a video with that rattle (is this similar noise to your case?):
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x530/xk_aspirator_5bd038c238cfac4f578de3066946fb992b637f66.jpg)
NOTE: the dash veneer has to be removed to see this and my car is RHD.
Yep, thats it. And I very grateful to You, guys🙏. I clean it up and now I hear the silence. Except for suspicious noises described above.
kj07xk (10-14-2021)
Thank You, Graham, for Your help and to all.
Rattle noise is coming from deflector shield (part 8)
It was quickest repair I had. The shield just was bended and was knocking on cable casing from vibration.
(2nd image)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/674x785/7557dd5a_a89c_4e27_ad60_819b64bf813e_fc3e016be9fd5274f555a9fe732a9635865026cb.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1334x750/db05f74d_b798_4524_bfa4_d3d6a7f6fad2_91d256b61e4d4c4c64381231b58aae21b9437c35.jpeg)
