Re: XK Exhaust
#42
For anyone interested, I've got my OEM back box and pipes from my 2010XKR sitting around someplace (have Mina performance exhaust as replacement). I'd rather have someone use it than have it sit. Also, this week I replaced my mid-resonator with an X-pipe, so I've got that as well with the attached pipes. By the way, what a big difference in sound and performance in case you're thinking about doing the same.
elindo (10-01-2016)
#44
gh27 (10-03-2016)
#45
#46
Received 2,048 Likes
I'd suggest starting with the XKR backbox, and see how that suits you. Then the X-pipe if 'needed', and finally lower cell count cats.
I've found that the XKR backbox is alone is just fine for me. Any louder, and then the wife's complaints will start to drown out the exhaust. You need to pick your audible sweet spot.
#47
#48
Probably want to make sure they use stainless steel, so you don't get galvanic corrosion and rusting.
#49
My car is a 4.2 XKR but here goes:
Standard "back box" still on:
Attachment 151776
And off, just requires bolts to the middle section pipes undone and hangers popped out of the rubber mounts:
Attachment 151777
New heatshield in place (old one had vanished somewhere along the line):
Attachment 151778
New box in place, refitting is the reverse of removal:
Attachment 151779
Lovely pipes, they didn't stay clean for long though:
Attachment 151780
Attachment 151781
First start!
Jaguar XKR - Spires Stage 1 + Elite RR back box - First Start - YouTube
And some revs:
Jaguar XKR - Spires Stage 1 + Elite RR back box - YouTube
That's the Elite RR rear silencer, already have the Spires "Stage 1" middle section with resonator deletes and a X-pipe.
Attachment 151776
Attachment 151777
Attachment 151778
Attachment 151779
Attachment 151780
Attachment 151781
First start!
And some revs:
hey 8 bit.. it has obviously been a while, but I recently bought a 5.0 xk, do you think I will get the same sound out of it if I completely copied your setup?
#50
Not exactly no - XKs sound a bit different due to being naturally aspirated, different compression ratio etc compared to an XKR. I've always preferred the XK sound, just preferred XKR performance more. Your XK will only have one center silencer whereas the R has two as standard, personally I would start with just upgrading the rear silencer and see where that leaves you.
Arminius (12-04-2022)
#51
I was really astonished to hear how ur xkr sounded, so deep and rich with tune. Anyway, by upgrading you meant the elite back box? I saw their back box on the website but there was a rr behind the name, are they the same model?
#52
No problem. Bear in mind also, that car was a 4.2 XKR, your 5.0 has a different engine, think different firing order too. I don't think you'll be disappointed though.
Yes their exhaust seems to be known as the Elite RR exhaust, not sure why. You'll need to replace the valance trim piece that sits in between your existing exhaust tips as the Elite back box comes with quad outlets, as an XKR would have, so you'll have to factor that in too. I don't think they're expensive though.
#53
#54
Happy Holidays all
Jumping in to ask if anyone has removed the XK rear silencer and gone with straight pipes.
A local muffler shop previously said a couple hundred bucks to add stainless pipes and use the existing tips.
I prefer that rather than $600 or so for the Adamesh Stage 1, but I'm concerned about the amount of noise and any potential droning at speed.
You Tube has too many videos that make my head spin.
#55
I have and it drones badly. It makes way too much noise at normal driving speeds in D. Ive tried DS but the wear and tear that comes from aggressive downshifts is not worth it. Best thing to do is remove the center and add an xpipe along with an XKR rear box. Zero drone, and lots of go that matches the exhaust bark. Ive been through several mods, and as much as I like a nice exhaust note that tells me what gear Im in, the last thing I want is an obnoxious exhaust that makes passengers want to get an Uber. So dont go that route. The key is to control the noise at the very end of the exhaust system.
#56
I thought about going the XKR box route, but the parts guru at Renaissance Motors here in Sarasota told me one (if he could find one) would be more than double the price of the Adamesh Stage 1 system.
But I just jumped on Ebay and found a couple of reasonably priced XKR exhausts, so all may not be lost.
Happy New Year
#57
#60
Jeremy07XK
11-05-2022 01:50 PM
