Rear Brake Pads Estimate From Dealer
Interesting... Anything is possible, but something would have to activate the brake for it to do so....
I guess if you're in doubt, one could just pull parking brake module connector, or the battery lead.
I am not a Jag mechanic, but have done dozens of brake jobs in my life (have never taken a car to a shop for it), so I just took a look at it, and went to work... I was prepared to have jag calibrate the system if needed, but it was pretty straight forward, and worked well when I was done.
I will warn, that if you lack mechanical skills or proper tools to re-torque things to spec, I would never recommend you work on your own braking system.
-Vince
-Vince
On the Alcon brake system 2008-2009 Portfolio Editions, the rear braking system has 2 calipers. The red Alcon 4 piston caliber and a black Brembo brake caliper for the emergency brake. The Alcon caliper is large while the black Brembo caliper is quite smaller compared to the Alcon.
Vince have you worked on the later model Jag XK's (2010-new) rear brakes. The above post gave me the indication that you were familiar with the XK E-Brake system but your above post gives me the feeling that you have not. Does the electric drive motor use external cables or are they integral to the caliper. Can you please describe the process to back off the E-Brake. Do we need to disconnect the module and apply voltage to a pin in a connector to operator the e-brake motor or do we need a diag. tool and go into the OBDII port to make it function. Just curious here
My service manual only covers up to 2010, as does my illustrated parts breakdown. The diagrams still show the second generation with standard calipers just to alleviate your fears of motors combined with calipers, and to me, a caliper is a caliper is a caliper...
In fairness, I am a skilled mechanic, caring for my own cars for 40 years, so very little maintenance frightens me. I found the job no more difficult than any other brake work.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
If cautions exist warning of bodily harm, then by all means, heed them.
Last edited by CleverName; 06-17-2014 at 12:53 AM. Reason: Corrected number of years
Mine is a 2007, so no I have not worked on later models. I used no OBD tool, or special tool outside of needing a piston retractor that fit the Jags pucks.
In fairness, I am a skilled mechanic, caring for my own cars for 40 years, so very little maintenance frightens me. I found the job no more difficult than any other brake work.![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
postscript to my brake job...
Two doors down from the Jaguar dealer, where I had my appointment, is an independent foreign car repair shop. They (All Foreign Auto Repair) specialize in Jaguars.
So, I went in and they did the rear pad replacement, using OE parts for a grand total of $253 tax included. This is compared to the $400 estimate from the dealer.
I believe I'm safe in saying, we are all willing to pay the price for the care of our cars, we simply don't enjoy "over paying" when it becomes obvious.
All's well that ends well...
The following 2 users liked this post by Tahoe Dave:
CleverName (06-19-2014),
Panthro (04-10-2016)
#30
I had my 2008 XK serviced last week at the dealer, in the Bay Area. The Service Adviser informed me that I need to replace the rear brake pads. He told me that the cost would be almost $400 for pad replacement only. They do not machine the rotors if they have the minimum thickness, which is the case for me.
I am curious if anyone out there has had the pads replaced, without machining the rotors? Additionally, I would like to know if the price ($400) is in line?
Thanks in advance...
I had them do it because the rear brakes are an integral part of the traction control system. I don't think that would have prevented me from doing it myself...
I have actually had to replace the rear eBrake pads on my DBS. The pads from Aston were about $700. But, the pads are *exactly* the same as the ones that fit several Jag models, such as the 2009 S Type R. And, at $125 a set I saved quite a bit!!!
KarimPA
09-12-2015 08:15 AM
