Rear brakes on new XK...do they require a special tool?
I'm assuming that installing front brake pads on the 07+ XK/R is a fairly simple installation. If I am wrong please correct me.
On the rear brakes, is there a special tool needed to compress the rear pistons? Are there any special tips which will help make the job easier?
Thanks in advance
Thanks in advance
The rears are simple with a piston retractor tool to rotate the pistons back into the caliper. You can use a pair of needle nose pliers but Harbor Freight has the tools for about $35 or you can usually borrow them from Autozone for free. It's usually good practice to connect a bleeder line and drain out the stagnant fluid from the caliper out the bleeder rather than forcing it back into the brake lines/abs/mc. also remember to take the caliper apart at the slide pins not at the mounting bracket and to use a good quality synthetic caliper lube for the pins when reinstalling them
rscultho (09-01-2011)
It would make it easier but if you try to pull the whole assembly at once you wont get the pads past the ridge on the edge of the rotor. Unlike the fronts where you can just compress the piston by pushing on the pads the rears wont retract with out the tool so you need to pull the center section first.
philwarner
09-05-2015 10:05 AM
