Rear fog light question
Yes I did Google it...but I need to hear from the gurus -
I put on my rear fog lights for the first time and I only have one working [drivers side]. Is this correct? My research tells me that this is how is should be [because if both are working then it will appear that you are braking all the time]..
What say you?
What say you?
Received 2,012 Likes
Why do 4.2L models have only one fog light? The fog light is always on the driver's side; right rear on RHD cars and left rear on LHD cars. The reason is because you're more visible to drivers behind you when that fog light is nearest the center line of the roadway. Also, since that rear fog light is as bright as a brake light, it's less likely that a driver behind you will confuse a single bright tail light with your brake lights. European drivers are more tuned into this feature than we are because I think that's the law on the other side of the pond. See my post #6: https://www.jaguarforums.com/forum/x...lights-155495/ for more details.
Ozmag (01-09-2016)
I think the single rear fog light may have been a statutory/legal requirement in UK in 2007.
As mentioned above, it is placed on the driver's side (left in N. America and right in UK)
In my opinion this single rear fog light is more confusing to other drivers than useful. I have found it better to use emergency flashers in severe fog conditions.
I also disliked the single backup light.
I wanted dual back up lights. I found on eBay UK a left-side rear light assembly for about $50. I swapped it in my '07 and now have two back up lights. I disconnected power to the abandoned rear fog light, and simply connected the new backup light to the preexisting backup light.
I don't like the pulsing of the backup lights; and much prefer a steady light beam. I suspect the pulse control/function is buried somewhere in the vehicle's software. Does anybody know how to change this pulse to a steady beam? Thanks.
You could add a relay, triggered by the pulsing backup signal, and then feed the lights a steady 12v. Not sure if the steady 12v will harm the lights or not.
Search for the thread about installing LED tail lights, and you'll find a link to a PDF file by George Kale, where he shows the parts and connection to add such a relay for the LED lights.
You'll only need one relay, as you only want to run the backup lights from it.
daboss085
08-18-2012 12:42 PM
quaker13
11-21-2011 06:41 PM
