Rear lights LED conversion
Anyone done the rear lights swap for the LED units?
I assume the lights from a 2014 car will be a straight swap for my 2008 stock units?
I read a while ago than I would need to swap at least one of the wiring looms so the connectors mate but that thread I think used resistors added so no errors throw up.
I've heard to put in stop lamps/holders from a trailer light board and hide inside the boot/trunk as don't suffer with the overheating that resistors can suffer with?
Is it fairly straightforward and has anyone suffered with errors? I really don't want errors thrown up as annoys the hell out of me!
Anyone point me in the direction of a help sheet for doing this? Not a cheap mod so wondering if worth it but does make it younger looking.
Chaos236 (04-22-2018)
Swisstone (04-12-2018)
I did the upgrade with lights & harness purchased from SNG & instructions from George Kale, it was very simple to do.
Here is the link to his instructions PDF https://www.jaguarforums.com/forum/a...ps-upgrade.pdf
Received 1,975 Likes
Did the George Kale method also a couple years ago,no issues, looks great. Also got the lights and harness from SNG Barratt, great company.
The following 2 users liked this post by kj07xk:
SNG Barratt USA (04-12-2018),
Contacted Adamesh here in the Uk today about buying just a modified wiring harness. Not sure if they have now changed their method but the use the extra bulb holders rather than resistors that can get hot. They said if you send them your lights, they test for no errors.
Thanks! I see that help guide is from a convertible with a boot rather than a hatch. Not sure if harnesses are the same but assume so. Are the old lights easy to remove as looks like the fixing is slightly different. The lights I'm buying are from a 2014 car so hope they will fit my 2008?
The lights will fit, they are all the same size. I have units from 2014 and 2015 cars on my 2007.
Thanks, straight out as in rearwards I guess. The help guide has an arrow pointing inboard (not sure what that means) but as the studs point forward, as you say, they must be pulled rearward. Hopefully will become clear when I do it! The new ones look to have three threaded studs but the old ones look to have two and a fastener type stud when looking at the pics.
You're correct, three threaded studs on the new, and two on the old (plus that press fit stud on the front).
ultraman206
01-15-2018 11:17 PM
JessN16
12-25-2017 04:55 PM
Kikevzqz
12-16-2014 01:47 PM
