Rear quarter window trim
X150 coupe owner (02-26-2022)
It's very easy to remove the rear quarter glass:
It's not as easy to remove the bright aluminum weatherstrip trim. It's a snug press fit, and you have to be careful and work slowly so you don't bend or damage that very expensive molding. From an X351 XJ, which is similar to the X150 XK/XKR:
See:
https://www.jaguarforums.com/forum/x...lation-223782/
See:
u102768 (02-28-2022)
However, the cost has taken a serious jump. When I replaced a door waist rail on my 2006 XK, it was under 50 UKP. The waist rail is now 162 UKP from JLR in the UK and likely to be even more in the US.
Stuart S (02-28-2022)
The trim around the back window is held on by clips as I understand it. A few guys have removed it so maybe one will chime in.
I asked about it awhile ago and the response I got was that the clips break when removing the trim and you can't find replacements. I dunno if it's true.
I pulled the trim from my 05 Super V8 and broke half of the clips but was able to plastic weld them back together. I have no idea if the clips on both cars are the same.
When you so get it off will you please do us a favor and take copies pictures or even video the removal and reinstall?
X150 coupe owner (03-01-2022)
I will be videoing it and will place it on the forum. Will hope all goes well.
Regards Paul
X150 coupe owner (03-02-2022)
