Rear Right Ride Height Sensor
Just the other day I was driving my 2010 XK and got the warning light "adaptive dynamics fault" and felt the car firm up clearly driving hard.
Luckily I have a verily good OBD2 code reader and it pointed to the rear right ride height sensor as being the problem.
So I have a couple of questions for those here more knowledgeable than me.
1. What is the part number of the sensor?
2. Is there a good aftermarket alternative to buying Jag OEM?
3. Does the car need to be calibrated after putting in the new sensor or can I just put a new one in and be good to go?
Hi rgfb62,
I'm in the UK and we're experiencing some unusually hot weather at the moment (30 degree centigrade). I have a 2010 XKR and, yesterday, out of the blue it exhibited the same symptoms as yourself. I have a hand-held
diagnostic reader (icarsoft) and that showed right rear ride height sensor. I deleted the code (C1A06) but every time I restarted the car it came back So, it looked like I was going to be looking for a new sensor. However, having deleted the code for the fourth time I then disconnected the battery overnight. When I re-connected it the next morning there was no warning and the functions all work as normal. I'm wondering whether this hot weather may have someting to do with the symptom ?? Before you go out and but a sensor (I believe they're around £130 GBP ($175) from the main dealers I may be worth trying the same as me ?? Good luck - keep us updated.
fxdwg (07-21-2021)
Thanks to Alan at XKEC forum:
Ride Height Sensors
Front Left Sensor : White/Black
Front Right Sensor: White /Blue
Rear Left Sensor: White/Green
Rear Right Sensor: White/Red
(all have supply on White (Pin 13))
Accelerometers
Front Right: Green (Pin 22)
Rear Left: Green/Orange (Pin 17)
Front Left: Green (Pin 10)
(all have supply on Yellow (Pin 25))
I found no voltage on white/red right rear sensor, confirmed today by diagnostics.
Ride Height Sensors
Accelerometers
