Rear View Mirror
Hmm.
Well, I'm working on a front / rear view camera solution. Some off the shelf stuff might work, but that's not really my style.
I'm going to build it so whenever you are in reverse it shows the back camera and whenever it's in 1st gear it shows the front (for parking). If neither of those are happening it will show some engine diagnostics, boost / voltage / etc. It will do all this automatically no button presses.
peterv8 (07-26-2019)
Interesting project. You can add rear view camera replicating stock newer models following this thread. It will get you what you want which is available in newer models no buttons to push:
https://www.jaguarforums.com/forum/x...08-xkr-198002/
For 1st gear to trigger a forward camera, this will be a bit tougher maybe. Since gear changes are handled through the CAN Bus and Most to the TCM, the only thing I can think of is the 1st gear display lamp in the gauge cluster. If that's accessible and the correct voltage....
Regarding display of other things while driving such as boost etc, can't help but watching with interest. GVIF via torque pro is the only way know of but that goes through NAV and you have to push a button.
Others have called out the issues with removing the rear view camera. I think it will throw codes as well.
Watching with interest
vdpnyc
01-05-2020 02:29 PM
SmoothOne
05-31-2007 07:44 AM
