Rear window of convertible
#41
The rear glass repair is done from the outside, with the top up and engine off. Lock the doors and keep your Smartkey in your house so you don't activate Convenience Mode and your battery doesn't drain.
Buy a CTEK and stop worrying about your battery.
https://www.jaguarforums.com/forum/w...d.php?t=218673
#42
#43
Hi Red,
I just wasn't sure if the repair would be OK with the top up and fully latched because of tension on the material. With the top partially down I was not sure if the battery would not drain and if the car would be properly locked to prevent the battery drain which I understand is an issue with this model. So I guess it should be all the way up and latched.
#44
If you have a CTEK or other quality battery maintainer, you should use it while you're doing the repair just to make sure that you don't run down the battery. Unless your X150 is a daily driver at highway speeds for at least 20 minutes (to keep the battery fully charged), you should use a battery maintainer. All sorts of electrical gremlins happen when the battery isn't fully charged. A CTEK or similar battery maintainer is a cheap investment to avoid problems.
#45
#46
Budster,
Your 2010 XKR has a Battery Management Module attached to the negative battery terminal. For that reason, never attach an auxiliary negative battery cable (jumper, charger, maintainer) directly to the battery negative terminal. Instead, attach that negative cable to a chassis ground.
I attached my battery maintainer to the remote battery terminals instead of directly to the battery. The remote positive terminal is under a vented black plastic cover on the left side of the trunk. Remove that cover and it's easy to see because it has a red plastic cover. The negative remote battery terminals is a bolt in the spare tire well, near the latch mechanism.
Details of how I wired my maintainer is in this old thread. It's not a CTEK, but the hook up is the same. I have a CTEK MUS4.3 on my 2013 XJ and prefer it over my old BatteryMinder, which still works.
Unfortunately, the photos I posted in this old thread are no longer there. But the text should help.
https://www.jaguarforums.com/forum/w...ad.php?t=73471
Stuart
Stuart
#47
I'll add, in addition to what Stuart stated, it's best practice to make your connections for charging "first" before plugging the CTEK into a power source.. I walked the "extra mile", and installed my CTEK on the side panel of my vacant tire well. The charging side I followed Stuart' advice, picking up point sin the trunk side panel area. For power I added a marine grade male receptacle with cover in the rear exterior Valance. it is out of site when viewing from behind.
As for the top, I too, left the top in position as I could se shrinkage was minimal. Since most all of my separation was in or just to the side of the window, I stuffed a swim noodle between the rear shelf and glass to support the glass when applying the "clampits" and wood paddles.
If need, I can add details on both these projects. YES, RHINO GLUE ROCKS!
MarkyUK (06-23-2020)
#48
Stuart S (06-23-2020)
#50
RedRider48 (06-23-2020)
#51
#52
#55
ralphwg (06-25-2020)
#56
#57
#58
The following 2 users liked this post by Stuart S:
NikiJ (01-28-2024),
RedRider48 (07-02-2020)
#59
#60
kj07xk (07-02-2020)
