Rear window Heater always on?
mosesbotbol (03-01-2016)
Heated screensThe front (
F
) and rear (
R
or
REAR
) screen heaters
may be switched on and
off in any mode,
including system off.
They will only operate
when the engine is running.
The front screen heater switches off
automatically after 6.5 minutes. The rear
screen and door mirror heaters switch off
automatically after 21 minutes.
The screen heaters can be manually deselected
using the buttons.
In cold ambient conditions, at the start of a
journey, the front and re
ar screen heaters will
switch on automatically for the timed period.
The rear heated screen will come on at
temperatures below -1°C (30°F) and the front
screen will come on below 5°C (41°F)
F
) and rear (
R
or
REAR
) screen heaters
off in any mode,
using the buttons.
The following 2 users liked this post by jagtoes:
amcdonal86 (03-01-2016),
White Bear (03-01-2016)
