Rear Window Sunshade/Cover fastener
Great idea Rich...its so darn small my old eyes missed the print the first time. Info molded reads exactly: >PA6< 2 southco
I would categorize the part as a "cam/compression latch" as the large handle piece folds 90 degrees to compress a rubber tube. Friction fits in the mounting holes in 2 of the 4 points around the Coupe's rear window. I'm doing a bunch of different searches now but with out much luck!
I think that is C2P19092. About $20 list at the dealer, $15 online here: Jaguar Parts - Direct JPLV Porsche Parts.com
This is exactly what you get when you order the above part number from that company. You do get the acorn nut and the rubber spacer. 2 for a little less than $50. The dealer wanted $70 each.
This is fantastic. I thought that it might not come with the nut and spacer, but it is all there. Thanks!!
Just for anyone looking at this thread in the future... I lost the rubber grommet in the hatch, and had to buy replacement parts.
C2P24519 is another part number that works and is only ~$8-10 at the dealer.
https://parts.jaguarpalmbeach.com/p/.../C2P24519.html
For some reason, C2P19092 is the same part at almost 4x the price ($27)
https://parts.jaguarpalmbeach.com/p/.../C2P19092.html.
I can confirm this as I just received 2x C2P24519 for $20 delivered to my door, but it would have cost $60 for 2x of C2P19092.
u102768 (07-07-2020)
99xk8guy
06-05-2023 06:28 AM
