Recommendations for OBD II readers
#41
As you go through the menus just choose Control Unit rather than Auto Scan:
Then select the PCM:
Then select Live Data:
And you are there:
I don't like that you can't create dashboards so I use other apps for that although they don't have access to so many metrics.
Reverend Sam (02-09-2020)
#42
http://britishdiagnostics.co.uk/
Software is on a virtual machine and installs on a Windows laptop. For X150 does everything the factory unit does including subroutines to reset windows, seats etc.
Have you used British Diagnostics V130 product with good success so far??
I've just semi retired recently and am looking beyond the bluetooth/wifi iPhone connect basics form CarScanner to be able to read/clear and adjust parameters with my 97 XK8 Coupe. Are you happy with this unit and their delivery/support??
Also was there much of an issue setting up a Virtual Machine in your Windows 10 which I presume you would have to have doen to support the product?
Appreciate any thoughts
Dave
#43
I'd completely avoid anything that British Diagnostics sells. They are all clones of clones with bootleg software. Also, the BD setup has been known to do weird things to the cars to which it has been connected. I'd CERTAINLY not try to program/flash any modules nor mess with the CCF with their kit. KABLOOEY and there goes $50k worth of car.
#44
Appreciate the honest response.....which begs the question what is your 'weapon of choice' though I see you're sporting an X150 but if you have experience in this area I'm open to recommendations. I've also been looking at Autoenginuity's products but user feedback is everything!
I would dearly like to be able to alter basic parameters in certain modules (e.g. up HVAC fan speed if I add a cabin filter, exercise the ABS when I do a brake bleed etc. etc.) as well as diagnose DTCs as and when they occur. At the moment with my $20 ELM327 bluetooth module and iPhone 6 I have no Jag specifics!
Cheers from across the Pacific
Dave
#45
Thanks Cee Jay
Dave
Dave
I do have a Jaguar-Approved DA Dongle, which is a less expensive option to a Mongoose cable. While it was still fairly expensive, still less than half the cost of a Mongoose. It's worked flawlessly.
While I don't have a subscription to SDD, I do have a copy of a registered version, and a couple tweaks to keep it alive without internet (which would overwrite my tweaks and make it fail) on an old stand-alone laptop dedicated to SDD.
I also have a Bluetooth interface for the Torque App, which I use constantly as it's permanently feeding data to my dash TSD, virtual gauges and such. I've used the Bluetooth with Torque for doing a quick fault code check to get me thinking in the right area, then if needed I'll fire up the SDD and take a better look around stuff. Plus, I've reflashed several modules and modified the Car Configuration File a few times.
#46
CeeJay, is this the dongle we should get? And after we get that where is a good place to get the SDD program? I want to use it to calibrate my seats because my son broke it again and I don't want to pay over and over to get them to reset it. I also have a a Range Rover and would like to use it for diagnostics on that.
https://www.obd2tool.com/goods-4742-...and+Rover.html
#47
#48
#49
It's already been done for you guys with 2010 onward. You just need to apply it:
https://www.jaguarforums.com/forum/g...p-more-213503/
Thanks also for linking to this, hadn't seen it before. Just installed the PID's and it works great with my $9.99 ELM327 Norsway unit purchased from Amazon a long time back.
#50
#51
If not and it's confirmed no chinese copy, I might buy one!:-)
#52
OBD II reader + app (iPhone)
Hey guys,
I have a 2010 xkr75, I also found it frustrating with the lack of dials/info whilst driving - specifically I wanted to know oil pressure and voltage + engine temp... so I could drive with spirit ASAP... I also didn’t want any lag that is common through Bluetooth so I went for a Wi-fi variant OBD II reader and app from OBD link... works wry well on my iPhone.
However, also bought DashCmd. It has a better dashboard setup (for me)... except that, on more than one occasion, the car has reacted to that setup (app). The car cuts out. Loss of engine, alarms going off, no brakes, no power steering, nothing. Not even able to activate hazard warning lights. Very scary and lucky I wasn’t on the motorway or haring down a twisty road. So, OBD link - good, dashcmd - bad.
