Removal and exchange of gear shift module
Does anyone have any experience or instructions on how to remove the gear shift module in the central floor console? When I bought the car (a 2007 coupe) it had several patches of black missing from the top plate which looked hideous so I looked for a replacement and have managed to find a complete shifter with a near perfect black plate. I would now like to change the whole unit over as it looks well nigh impossible to remove the plate without complete disassembly of the module. The workshop manual refers to more complete disassembly of the console than may be necessary so has anyone some advice for me before I break something!? For example do I need to remove the side panels of the console and is any adjustment necessary to the gearbox cable when reassembling?
Cheers,
Mike
Cheers,
Mike
Received 1,975 Likes
IIRC, the side panels just pull off, but check the service manual to be sure. Use a marker to mark the adjustment linkage parts (nut, threads, etc), so you can line everything back up again when reinstalling. Did that when I removed my console, and no additional adjustment was needed after reinstalling.
The following 2 users liked this post by kj07xk:
Sailor Mike (02-09-2024),
steve_k_xk (02-09-2024)
Purely by chance I found a previous thread which explains mucho. https://www.jaguarforums.com/forum/x...uestion-265076.
lalavfr (02-09-2024)
Pretty easy to R and R Mike,
1. Remove the shift area wood trim.
2. Remove screws that are attached to the console side covers
3. Remove both console side covers
4. From the left side disconnect single electrical connector
5. From the right side take a screwdriver and pry off the cable attachment
6. Remove four screws that hold down the shift unit and out she comes.
I have never had to readjust anything with the cable attachment as of yet. Should be about an hour job.
Sailor Mike (02-19-2024)
