Removal of windscreen washer filler neck
I need to remover the windscreen washer filler neck, to be able to remover the ABS/Traction control unit. How do I remove it without breaking anything? It is plastic, and appears to be flush with the metal, with no attaching hardware. Do I merely pry it off, or am I likely to damage it if i do. If so, how to remove it safely? Thanks.
The following 2 users liked this post by MarkyUK:
Cee Jay (09-20-2020),
St. Stephen (09-20-2020)
