Remove Console & Head Unit Trim
I'm trying to install a C2P-16491 Iphone package on my '08 XK and have found a couple of threads in this forum pertaining to this. It seems a couple of guys have done the install themselves but there no detailed info on removing the console trim or the headunit trim. Wondering if anyone could share their experience with this? I don't want to wind up needing new trim because I chipped the existing.
Also, for anyone else interested in doing this project there's a software install that's require to allow this unit to function and it has been long since document here in this forum. What hasn't been mention (I don't think) is there's a software ROM upgrade. But what's unclear at this point is whether this is "the software" required for initial install or its an upgrade to the initial install software. I'll know more once I get the unit installed and running. The ROM can be found here;
http://www.dension.com/jaguar/?agree=0&xk=0
Anyway please help if you know how to remove the wood trim.
Thx in advance
Btw, c2p-16491 can be found on jaguarparts.com for $237 now.
Thx in advance
Thx in advance
Thx in advance
When they installed my unit they added the ipod connector to the centre console and the USB/RCA input in the glove box. I dont know how they got to either.
I do have one problem with the installation that they haven't been able to fix. Whenever I select the auxiliary, even with nothing connected to it, I get alternator "whine". It is driving me nuts. The dealers answers was to "turn up the volume and you will not hear it". The stupidest thing I have ever heard. I will be spending sometime this summer to see how I can get rid of the noise. I am hoping I can eliminate the problem from right behind the deck unit since I know how to get there.
Here's the info
I thought I did a pretty could search of this forum but just didn't see this; https://www.jaguarforums.com/forum/s...ad.php?t=49563
I guess I'm using search too much instead of just looking thru the threads. Anyway, as soon as I'm done installing I'll find out more about the ROM upgrade.
I got that console project behind me, thankfully. I absolutely hated "prying" on the console trim to remove it. I was dreading the sound of expensive Jag veneer cracking. Those retaining clips are very stiff and it requires a lot of effort to get them to release. Mine did make a "pop" sound when it finally let go and scared the crap out of me.
I started on the narrow "legs" around the ashtray because they are likely the most delicate and then worked my way back. Worked a very thin blade putty knife into the seam until I could switch to a wooden wedge. (I used a shim like you use for installing house doors) I then pushed and tapped to force the shim in rather than prying. Note where the retaining tabs are located from the illustrations and work around them. Once the veneers are off, it's pretty easy to figure out the rest of the disassembly.
The radio/climate control veneer was much easier just prying with my fingers, starting from the bottom. It seemed sturdier.
Good luck!
You just saved me some typing!
Good luck!
Good luck!
And yes you're right the top was a piece of cake. It got dark here so I couldn't finish completely but was able to start it, check the radio, the cd player and nav system so I guess I didn't break it. Tomorrow I'm going to try the ROM upgrade to see if it's the complete install or just a ROM update for the Dension unit. I'm thinking now it's just for the Dension unit.
Wolfy
05-28-2024 08:06 AM
