Remove sound horn alarm
Does the sounder beep when you press the lock button the first time, just once? Or does it beep only when you press the lock button two or more times?
It shouldn't beep with just one push of the lock button. If your outside mirrors automatically fold and you have that feature activated, your mirrors will fold inwards when you press the lock button. That's your visual confirmation that the doors are locked.
If you press the lock button immediately after the doors have been locked, the sounder will beep. It's an audible error message. To stop it from beeping don't push the lock button twice.
Or you can remove the sounder. But it's a useful device because it also warns you that a bulb has failed together with a warning light on the dash.
Where is that horn to be able to disconnect it?
The passive anti-theft horn is located in the RH rear corner of the engine compartment and attached to the bulkhead. Have you tried downloading the service manual?
http://www.mediafire.com/?2ssiyne7ma1fs#0ec9q9v8qhanh
ralphwg (03-29-2020)
My car does it right, but I don't want it to beep when I lock safely.
Thanks for your attention
In the end, and thanks to your help, I managed to find the blessed alarm horn.
Now it no longer sounds when I lock the car in lock mode, but it indicates this with a longer flash of the turn signal lights.
Fantastic and without having to pay money to deactivate the system.
peterv8 (03-29-2020)
I don't understand why it says the beep indicates an error. In the car manual it is very clear that when I close the car by pressing 2 times the whistle will sound indicating that the lock is locked so that the doors cannot be opened from the inside.
European models have double locking. The beep on the second push is to remind you to make sure you didn't leave your kid in the car.
My fault, I should have noticed that you're in Spain. Glad you got it sorted.
Buzzer (04-28-2020)
Double locking is disabled on North American models to comply with US law that considers it unsafe if children are left inside. The beep on the second push is an error message. Every year, kids die from heat stroke when left in a car. Being able to open the doors from the inside whe locked can save lives.
I could not have imagined that in the United States you had suffered this type of accident with children. It is good to know it to take it into account and not to commit such a disaster.
Thanks for the info.
Greetings.
happens far too much and frankly once is too much. The powers that be ask adults to put their purses, briefcases, lunches, etc in the back seat so they're reminded the have a kid in back, while auto makers are working to create an occupancy sensor alarm functionality
https://injuryfacts.nsc.org/motor-ve...ssues/hotcars/
V7Sport (03-29-2020)
