Removing ECM to replace control arms
Hi all. I'm doing a bit of a suspension refresh at the moment. I'm replacing the drivers side upper control arm, the shop manual says removing the EMC is necessary for this. I followed the instructions in the manual, but it says to pull the three bolts holding the ECM down like that's an easy task. Not so on my LHD 4.2L convertible. One of the three ECM bolts is maybe 8mm from a metal bulkhead and the geometry of the parts surrounding it makes getting a socket or wrench around it impossible. Can't even reach it with needle nose pliers. Anyone changed an upper control arm (Left hand side) without pulling the ECM, or pulled the ECM sucessfully that can lend a little insight into this issue?
I'm also planning on tackling the upper and lower rear control arms tomorrow, I know I have to disconnect the brake line to change the upper, do I have to do anything special to the E-Brake? Anything else I should look out for?
Thanks in advance.
Thanks in advance.
I did it without removing the ECM. Disconnect the big square block connector held down by a bolt, then unclip and reposition the harness right next to the fuse box. I think I also repositioned the fuse box a bit too. Its a tight squeeze but you can get a ratcheting wrench on that nut (the control arm nut).
To get it back on, stick the bolt through a bit, then hold the nut onto the frame and start spinning the bolt till it catches the threads.
steve_k_xk (09-23-2020)
Sean W (09-23-2020)
I like that. First time I tried duct tape .... stay away from that - too much residue when peeling off!
Lance30144
03-18-2013 03:30 AM
