Replacement Front Bumper for 2007
Received 2,048 Likes
TX Nigel (07-21-2016)
Bumper Cover Without Front Parking Sensors
I needed a new bumper cover in June. There was only 1 in the entire country (USA). It had to be special ordered from the UK with an estimated delivery time of one month or more. Part number is C2P9867XXX List Price $1,360 but can be found at authorized Jaguar dealers with wholesale part websites for less than $1,000. Try jaguarpartsunlimited.com Don't buy the ones on ebay. They are all take offs from cars which have been in front end collisions and have been repaired with varying degrees of results.
Anyone know.... is there an easy way to change the J-Gate into the hockey puck? Probably not, just wondering.
Somehow I thought because they eliminated the 2 lower side lights and replaced it with the air intakes that the 2010/11 used a different headlight assembly. The headlight openings may be the same but the lower lights are now in the headlight. Then in 12 the nose and lights changed . So the 10/11 nose may fit and the 07 headlights will fit but you will not have the 2 lower lights.
No Fogsr
I think the fog lights are inside the 2010/11 headlights. I believe the 2010/11 headlights fit in the 2007/09 but have a different headlight arrangement. I thought someone here did the conversion but don't remember who.
Also in regards to the later model bumper 10/11, I would quite happily forgo my 07-09 fog lights for the updated look
TX Nigel (07-23-2016)
OK - various Jaguar websites show the following four variants of headlamp (Left & Right, Active & non-Active): C2P21141 C2P21142 C2P21146 C2P21147. These are listed as the OEM headlights for XKs from 2007 to 2011.
So, looks like I can use a 2010/2011 front bumper, keep the same headlights (and hood and fenders) and as Steve says 'forgo my 07-09 fog lights for the updated look'.
kj07xk (07-26-2016)
I found the link - 2007 xk upgraded with 2010/11 bumper
https://www.jaguarforums.com/forum/x...ncluded-93315/
And if you want to update to the F-Type look:
Unfortunately, it's not available as a kit. See: Jaguar XK super car styling
and
Stuart
and
Stuart
