Replacement Front Bumper for 2007
Old 07-21-2016, 06:49 AM
TX Nigel's Avatar
Default Replacement Front Bumper for 2007
Been scanning these threads for a while but haven't found a definitive answer to my question: Which years of XK front bumper will fit my (currently damaged) 2007 XK without modification?
Thanks for any advice.
Old 07-21-2016, 07:27 AM
kj07xk's Avatar
Received 2,048 Likes on 1,372 Posts
Definitely not 2012, or later, as the head lights changed in 2012.
If I'm not mistaken, the fog lights disappeared in 2010. So I think you're safe with 2007-2009 for an exact replacement. (Those are US model years.)
TX Nigel (07-21-2016)
Old 07-21-2016, 10:56 AM
Fstbmw1's Avatar
+1 with kj07xk. 3 years 07'-09'. If you shop around they can definitely be found. There are 3 on ebay at the moment.
Old 07-21-2016, 01:55 PM
captusnr's Avatar
Default Bumper Cover Without Front Parking Sensors
I needed a new bumper cover in June. There was only 1 in the entire country (USA). It had to be special ordered from the UK with an estimated delivery time of one month or more. Part number is C2P9867XXX List Price $1,360 but can be found at authorized Jaguar dealers with wholesale part websites for less than $1,000. Try jaguarpartsunlimited.com Don't buy the ones on ebay. They are all take offs from cars which have been in front end collisions and have been repaired with varying degrees of results.
The following 2 users liked this post by captusnr:
kj07xk (07-21-2016), TX Nigel (07-21-2016)
Old 07-22-2016, 04:45 PM
Fstbmw1's Avatar
If the bumper has been repaired it would be evident by viewing the backside of the bumper. The front, if repaired and painted properly, may not be as evident.
Old 07-22-2016, 06:37 PM
TX Nigel's Avatar
Thanks guys. I was specifically wondering about the 2010-2011 bumper and whether the dimensions and fit were the same.
Old 07-23-2016, 12:50 AM
steve_k_xk's Avatar
Received 1,555 Likes on 898 Posts
Same headlights , bonnet and fenders the 201/11 bumper will fit plus it will really update the look of your xk
Attached Thumbnails Replacement Front Bumper for 2007-c214748364813102010225252_1.jpg   Replacement Front Bumper for 2007-unknown-10.jpeg   Replacement Front Bumper for 2007-unknown-11.jpeg
The following 2 users liked this post by steve_k_xk:
kj07xk (07-26-2016), TX Nigel (07-23-2016)
Old 07-23-2016, 11:40 AM
Cee Jay's Avatar
Received 5,511 Likes on 3,242 Posts
Then treat it to the 2010-2011 LED tail light swap.
Anyone know.... is there an easy way to change the J-Gate into the hockey puck? Probably not, just wondering.
Old 07-23-2016, 11:51 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Somehow I thought because they eliminated the 2 lower side lights and replaced it with the air intakes that the 2010/11 used a different headlight assembly. The headlight openings may be the same but the lower lights are now in the headlight. Then in 12 the nose and lights changed . So the 10/11 nose may fit and the 07 headlights will fit but you will not have the 2 lower lights.
Old 07-23-2016, 12:15 PM
captusnr's Avatar
Default No Fogsr
Absolutely correct. A 2010 + bumper cover has the chrome vents in place of the fog light ovals
Old 07-23-2016, 04:10 PM
TX Nigel's Avatar
The headlights that I see advertized allegedly fit 2007 -2011. I had therefore assumed that Jaguar had done away with the fog lights altogether for US spec vehicles.
Old 07-23-2016, 05:48 PM
kj07xk's Avatar
Uh no. My front lower fogs work on my '07.
Old 07-23-2016, 05:52 PM
TX Nigel's Avatar
Sorry - I meant that if the front bumper changed in 2010 to remove the fog lights, but the headlights are the same from 2007-2011 then I presumed that there were no foglights on 2010-2011 models.
Old 07-23-2016, 06:44 PM
jagtoes's Avatar
I think the fog lights are inside the 2010/11 headlights. I believe the 2010/11 headlights fit in the 2007/09 but have a different headlight arrangement. I thought someone here did the conversion but don't remember who.
Old 07-23-2016, 06:46 PM
steve_k_xk's Avatar
It could surely be done for the right price although i imagine it wouldnt be cheap , however im with you on the idea of the LED taillight conversion!
Also in regards to the later model bumper 10/11, I would quite happily forgo my 07-09 fog lights for the updated look
Old 07-23-2016, 09:02 PM
TX Nigel's Avatar
OK - various Jaguar websites show the following four variants of headlamp (Left & Right, Active & non-Active): C2P21141 C2P21142 C2P21146 C2P21147. These are listed as the OEM headlights for XKs from 2007 to 2011.
So, looks like I can use a 2010/2011 front bumper, keep the same headlights (and hood and fenders) and as Steve says 'forgo my 07-09 fog lights for the updated look'.
Old 07-26-2016, 05:17 AM
steve_k_xk's Avatar
For those who dislike their 2007-2009 bumpers !
Attached Thumbnails Replacement Front Bumper for 2007-images-9.jpeg   Replacement Front Bumper for 2007-images-10.jpeg
kj07xk (07-26-2016)
Old 07-26-2016, 06:37 AM
kj07xk's Avatar
Sure, why not? Duct tape can fix anything (and you can get it in lots of colors too!).
Old 07-26-2016, 04:11 PM
steve_k_xk's Avatar
I found the link - 2007 xk upgraded with 2010/11 bumper
https://www.jaguarforums.com/forum/x...ncluded-93315/
kj07xk (07-26-2016), TX Nigel (07-26-2016)
Old 07-26-2016, 06:09 PM
Stuart S's Avatar
Received 6,389 Likes on 3,500 Posts
And if you want to update to the F-Type look:
Unfortunately, it's not available as a kit. See: Jaguar XK super car styling
and
Stuart
Quick Reply: Replacement Front Bumper for 2007
