Replacing CATS shocks with normal ones
steve_k_xk (04-08-2020)
ralphwg (04-08-2020)
The reason is none other than to value what CATS shock absorbers offer at the price they are selling, comparing them with normal shock absorbers in terms of performance and price.
Do the difference in vehicle performance with conventional shock absorbers or CATS really deserve that price difference?
and mount the conventional shock absorbers.
In this way it would not indicate any failure on the screen?
Go the BC coil overs I'm sure Jeremy can give you a run down on them
I've replaced my front shocks and tried 3 different spring combinations .
As I can see it will coil overs you have precise control of the height and damper rate resulting in better handling and also a positive weight reduction.
Another issue with the CATS system is when they fail they will revert back to the default mode being not soft which is quite comfortable but instead the firm mode which is bone jarring
Received 1,975 Likes
In this forum I try to communicate by making my comment with the Google translator.
The same goes for the comments that you put the other foreros.
Sometimes this translation seems so strange to me that I can hardly deduce what you write in your comments.
Without going any further I can explain that when you talk about "gearboxes" it appears to me in the Spanish translation as "transsexual".
At first I was surprised since I thought you were talking about another topic since in Spanish a "transsexual" is a man who has changed his sex.
My sincere apologies to all for not understanding comments 2 and 4.
Thanks for the clarification
correct and not failure or errors. It works perfectly. And yes I would highly recommend considering BC Racing coilovers.
The following 2 users liked this post by jahummer:
Sean W (04-08-2020),
steve_k_xk (04-09-2020)
