Replacing Rear Brake Pads
For a 2015 XK, do I need to do anything special with the Electric Parking Brake, other than the re-calibration after replacing the rear pads? (I thought I saw a procedure somewhere requiring releasing EPB tension by hooking up some Jaguar jumpers to the parking brake electronics behind the rear seat.)
luv2fly (05-13-2024)
I'm in the midst of replacing the rear rotors/pads in my 2010 xkr right now, and I used the e-brake release function via my neighbor's Autel OBD tool. This is the first time I've ever had to deal with an electric e-brake so I'm not sure if there's a procedure outside of using an OBD tool in order to perform the release/Off.
It's weird. When I pulled the Jag into my garage, I definitely didn't set the e-brake on. But when we ran the release function in the OBD tool, there were distinct noises coming from the rear brake area. It sounded like metal clacking and pressure being released. Maybe it actually didn't "release" anything (since, as you suggest, it wasn't really in the On position), but the car electronics just going through the release procedure always makes those noises.
bgpenguin21 (05-07-2024)
Unrelated thought... Am I the only person that has to take an extra second to think whether those tools are OBD or ODB?? After spending the last 20 years in technology roles, I always want to type 'ODB', like DB, for Data Base.
Am I the only one?
Anyone??
Dammit. ADD sucks.
![Icon Handball](https://www.jaguarforums.com/forum/images/smilies/icon_handball.gif)
The following 2 users liked this post by McJag222:
bgpenguin21 (05-07-2024),
Cee Jay (05-07-2024)
On Board Diagnostics.
Thanks all. My wife's Mazda CX-30 has an "EPB Service Mode" which you put the car into before working on the Rear Brakes. Further investigation reveals the CX-30 EPB is located on each rear caliper (a small motor and associated electronics) and does require this mode to prevent damage. Looks like the Jag EPB mechanism is actually a centrally located device with a cable running to each caliper. Again, thanks!
jjsandsms
12-08-2023 09:21 AM
ndy4eva
24
06-16-2010 05:20 PM
